as said callipers are a common problem, and a good place to start, wouldn't usually make the EPB flash though, if you are changing the discs at the back, then its worth checking the condition of the epb shoes in the centre of the disc while its off, older ones have been known to disintegrate. its not usual service item as they dont wear much, but worth looking at if you are in there, There is nothing that can't be fixed with a hammer😜😜
