Home > In Car Electronics (L322) > TV Picture gone awol!
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Not that I use it very much but noticed recently that the picture on the TV of my 2010 TDV8 has gone even though the sound quality of each channel is perfect. This all possibly happened when I connected up the wiring loom of a tow bar I put on but is this clutching at straws as nothing was really disturbed by the TV tuner. Sorry for my electrical stupidity but are there separate connectors for the picture and the sound to the dash? I dont have a dvd player to test this source and I dont have headrest screens to test them eiither. The dual vision screen definitely used to work fine and the screen is perfect for all other functions. Finally no error codes flag up on the IID Tool.
Any easy pointers?
Cheers
T
Post #472648 14th Mar 2018 9:49pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
As far as I'm aware, the TV picture/sound is all transmitted over the fibre optic MOST loop, so no separate connections for picture and sound.
Do you get any TV picture in the small preview box before you enlarge it to the full screen, or nothing at all?
Post #472657 14th Mar 2018 11:21pm
tomthevet
No picture on the preview either but sound crystal clear!
Post #472682 15th Mar 2018 10:17am
the tv picture normally goes blank when the FF is in motion or the gears are not in park.....
unplug the tow electrics and see what happens...maybe the FF needs to be told there are now tow electrics via the iidtool.. ... - .- -.
Post #472684 15th Mar 2018 10:28am
paulbrown22
But if you have a DualView screen, you should still be able to watch in DualView mode, from the passenger's seat?
Have you tried leaning over/checking from the passenger side?
Post #472686 15th Mar 2018 10:36am
good point Paul.. Thumbs Up ... - .- -.
Post #472698 15th Mar 2018 11:29am
tomthevet
Yeah tried the passenger seat view too and nothing.
Will find some time to empty boot and unplug towbar. Full of kit at the moment. But will report back once Ive had a look
Cheers guys
Post #472705 15th Mar 2018 12:58pm
tomthevet
Towbar unplugging made no difference (though plug was a bit moist due to the couple of inches of water sat sloshing around the spare wheel!). Anyway not to worry as never really use it but will try to check more once I get a chance. Cheers guys
T
Post #473417 22nd Mar 2018 12:18pm
