Home > Maintenance & Mods (L322) > Foam rubber blocks at rear of bonnet
Page 1 of 3 123>
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
Can anyone tell me what role the foam rubber blocks at the top rear of the front wings do?
A part number would be great (they are left and right handed).
Many thanks.
Post #472153 11th Mar 2018 5:00pm
Webbie
Mine have disintegrated too. I guess they are part of the sound insulation. If the parts low cost it makes sense to replace them.
Post #472154 11th Mar 2018 5:26pm
they come in two parts per side, called insulators...
LLR031809
LLR031810
LLR023472
LLP023473
cost me 9.19 plus vat [each] back in march 2017 ... - .- -.
Post #472157 11th Mar 2018 5:51pm
Philip
Replaced twice under warranty, third ones have now disintegrated. They soak up water badly.
Post #472168 11th Mar 2018 6:50pm
They are a water trap and can cause corrosion! They are also behind the bumpers and in the chassis recesses! All ready to rot the panels out in years to come! Rolling Eyes
Post #472169 11th Mar 2018 6:58pm
stoutgoose
Many thanks Stan.
Post #472171 11th Mar 2018 7:36pm
pld118
So, would you be comfortable taking them off and not replacing them on your car Craig?
Post #472173 11th Mar 2018 7:49pm
I have Ryan... Thumbs Up
Post #472217 12th Mar 2018 12:46am
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
I find the ones on my car soak up water really well! Sorry, couldn't resist, IKWYM.
Anyway, they are a poor piece of design, and if Craig says they aren't needed, that'll do for me.
If anyone can specify exactly where else they appear on the car (L322 in my case) that would be most helpful.
Post #472238 12th Mar 2018 9:09am
DrRob
Mine were in a Censored state and soaking. Removed. Time will tell if I need to replace them Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518810 17th Jun 2019 7:26pm
mpirie
Likewise, mine are falling apart and although I have the replacements, I can't see the point in fitting them if they'll just do the same again.
Mike
Post #518883 18th Jun 2019 9:25am
its when they crack that the water soaks in...my new replacements stayed dry..[until they get old and crack again] ... - .- -.
Post #518885 18th Jun 2019 9:31am
Baltic Blue
I have tried standing them in the sunshine ( last summer not this Rolling with laughter ) to dry them out which helped, then I sprayed them with a good coating of WD40, but next time they get very wet they are going in the bin.
Post #518888 18th Jun 2019 9:59am
DrRob
First run on A3/M27 without them today and I could not hear any difference.
I guess some cars whistle and some don't Whistle Whistle Rolling with laughter
I won’t be spending £48 on replacing them Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #518894 18th Jun 2019 11:06am
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
I want to replace mine but am slightly confused about the fact they come in 2 parts?
I can see a big block sat on top of wing when I open bonnet. Where’s the 2nd part go?
Cheers Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #525540 20th Aug 2019 2:06pm
Page 1 of 3 123>
