![]() | Home > Maintenance & Mods (L322) > Foam rubber blocks at rear of bonnet |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Are you sure it wasn't whistling because of where it had been dislodged to..?
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Thanks for resurrecting this thread!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
Hi Pete. It had broken into two pieces and fell down by the door hinge. I've just used some UHU glue to fasten the pieces together and I'm going to refit it and see if the noise goes away.
It's obviously a car specific problem, my 2002 ones had long gone and never had any noise, the 2012 ones were pretty awful so I removed them and it was fine as well...!!
Just noticed the left hand bonnet one is missing. The right one is all complete though. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1218 ![]() ![]() ![]() |
Regarding RJH's post about earlier models not having them fitted, just looked at my 2006, nothing there, and absolutely no evidence of any glue ever being in that vicinity, so RJH is probably correct.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
JLR main dealer couldn't be bothered to check they'd mangled one adjusting my bonnet during repair following a head on collision (along with a bolt missing from the new front grille, part of the old front bumper left on my IVORY back seats and a wonky numberplate). I encountered a squeak when operating the door and a whistle when driving also. So, a word of warning kids, don't necessarily trust paying a premium for main dealer to fix a car that they will do a better job. 2015 Range Rover Autobiography 4.4 SDV8 |
After refitting the foam the noise has gone. |
Mine's missing from the passenger side and I can definitely hear wind noise from that area and not from the drivers side so will try removing the drivers side one and to see what happens. 2012 TDV8 Vogue (L322) |
Drivers side removed and no noticeable noise today on the M-Way 2012 TDV8 Vogue (L322) |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Removed mine years ago, makes no difference at all. |
