Home > Technical (L322) > To Cooler or Not to Cooler
colinwebster
Hi Guys,
Ive booked in for a trans flush as a preventative service action not due to any faults......
My service guy who is a ZF trans specialist rather that LR specialist is strongly suggesting I should change the trans cooler at the point of service????
What are you views on this, do you think its warranted???
Also with a trans flush some say change the filter, some insist not??
Cheers Guys
Edited : ZF
Post #472106 11th Mar 2018 10:32am
Cooler: It is probably a good idea, if you are going for a megaflush, but would drain then change it before doing any megaflushing to prevent any gunk in the cooler getting spread around.
Filter: Yes change the filter too, well worth dropping the sump to see what you have on the magnets !
Also, DO NOT clear gearbox adaptations.
SAINTV8 did a howto on the wiki (cooler) .
Post #472129 11th Mar 2018 12:59pm
