Home > Technical (L322) > ‘07 TDV8 3.6 6 speed |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
One thing for sure is it's always worth checking the oil level first.. there is a procedure where the oil must be warm and engine running ... plenty of info and or vids on you tube about doing it
10th Mar 2018 6:55pm |
MartinM Member Since: 19 Dec 2015 Location: Oslo Posts: 16 |
Also check that the brakes are not sticking. A slightly sticking caliper can cause judder. Check if warm after a drive.
11th Mar 2018 7:50am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
The rear Calipers would be a good place to start. As said check for excess heat after a drive. The gearbox on the 3.6 is pretty robust and there are not many out there which have gone pop so hopefully it’s a simple thing not the box. There is nothing that can't be fixed with a hammer😜😜
11th Mar 2018 8:09am |
