Home > Technical (L322) > ‘07 TDV8 3.6 6 speed
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi guys,
My ‘07 TDV8 3.6 full fat has what I believe to be trans slip I.e. a juddering between 70 & 80 MPH.
Can this be cured with a gearbox oil change or is this something far worse?
Post #471984 10th Mar 2018 4:06pm
Bluegreygreen Rangie
Australia
One thing for sure is it's always worth checking the oil level first.. there is a procedure where the oil must be warm and engine running ... plenty of info and or vids on you tube about doing it
Dave 2010 TDV8 Autobiography
Past - 02 & 03 TD6 And an 1984 Classic
GAP Diagnostics
Post #472026 10th Mar 2018 6:55pm
MartinM
Norway
Also check that the brakes are not sticking. A slightly sticking caliper can cause judder. Check if warm after a drive.
Martin
Post #472082 11th Mar 2018 7:50am
The rear Calipers would be a good place to start. As said check for excess heat after a drive. The gearbox on the 3.6 is pretty robust and there are not many out there which have gone pop so hopefully it’s a simple thing not the box. There is nothing that can't be fixed with a hammer😜😜
Post #472084 11th Mar 2018 8:09am
