Home > Technical (L322) > Unexplained battery discharge????
Page 3 of 3 <123
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
The day before I left for Mozambique, I packed the car, parked in the garage, and when I tried to set off in the morning the battery was so flat it only just managed to open the driver's door!
I charged her up enough to start, took her to local dealer, where they pronounced the battery to be in good health!
I have had to be jump-started 3 times in the past 2 weeks Sad on the beach...
The cooling system fan just comes on in the middle of the night for no reason, and sometimes when parking and locking the car, the fan comes on and stays on until the battery is flat !
Sticky relay? Censored temperature sensor?
Post #44705 5th Jan 2011 3:51pm
terex48
United Kingdom 2004 Range Rover Vogue Td6 Alveston Red
I had a battery drain problem and found out it was the head lamp wiper relay , I pulled the fuse and have not had the problem since , I noticed it first by the wipers , they were not parking properly ( touching the bumper) I adjusted it then it was touching the bumper again . Not changed the relay yet as it is in behind the dashboard . 2004 Range Rover Vogue TD6
1997 Defender 90 300 TDI
Post #49131 6th Feb 2011 7:45pm
dan_uk_1984
If you put the fuse back in they should park propperly, there is no manual adjustment you can do with them, they have to sense that they are "home"
Dan
Post #49132 6th Feb 2011 7:57pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Baben wrote:
The day before I left for Mozambique, .........
......Sticky relay? Censored temperature sensor?
I'm thinking sensor. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #49133 6th Feb 2011 8:01pm
Baben
Well stealer says they did a software update during the last visit, and a month down the line the discharge hasn't happened again. Touch wood it's fixed.
Wish they could get the front suspension squeak and the rear door clunk sorted now Evil or Very Mad
Post #52776 3rd Mar 2011 6:59pm
Jackofq300
United Kingdom 2002 Range Rover HSE 4.4 V8 Zambezi Silver
getin same fan issues but the red light goes out n fan on st
andyw wrote:
you said you can hear a fan like noise coming from the centre console this could be that the final stage fan is not being told to go to sleep and or waking up intermitantly and draing your battery. the easey way to check is to
switch off remove keys from ignition
lock the car (with you in it)
there is an red led on the centre console near the terain / low gear switches after a s mins that should go out and the fan will stop
if they dont then the car is not going to sleep
the biggest tell tale is the fan will never stop
you need to be patient and stay for around 30 min tosee if the the car wakes up and the fan comes back on
mine took about 15 min to turn on a gain (i looked a little daft sitting still with no engine on or music Rolling with laughter )
if it it does come back on theHVAC is not performing and needs replacing
have fun dont forget the interior alarm sensor
regards
andy
Post #216238 13th Oct 2013 10:16am
Page 3 of 3 <123
