Home > Technical (L322) > Special features won’t enable
Bennyis01
England 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Hi
Can anyone help with this problem
I’ve a Range Rover vogue Se 2010 3.7ltr
Which when trying to activate snow mode or any of the special features but
it displays that non are available
I’ve tried disconnecting battery ,all kinds of stop start sinario with the ignition to no avail
Can anyone pls pls help
Thanks in advance
Jason [/img]
Post #470764 2nd Mar 2018 9:13pm
GraemeS
I expect that there is a fault with one of the pre-requisite systems, such as a brake, steering angle sensor or suspension system error. If you don't see any messages on start-up then the fault codes will need to be read.
Check your messages. What is the reason for the warning triangle?
Post #470826 3rd Mar 2018 11:38am
GGDR
on the 4.4 (2011) it'd be the adaptive damper cables which are quite an easy fix.
I don't think the 3.6 (not 3.7 btw) has this but i'm not 100%. Look at your strut towers and see if there is a cable going in around the top. search adaptive dampers here to get a better idea of what to look for.
My damper cables went (common) and then I could not select any special programs.
Good luck!
. Cheers, Greg
Post #470828 3rd Mar 2018 11:50am
+1 for checking the adaptive damper cables, though this tends to throw the adaptive dynamics fault message too, could be the yellow triangle message....
Check the cables going into the strut tops, they tend to break and can be soldered back together, or better still replaced with an upgraded cable. There is nothing that can't be fixed with a hammer😜😜
Post #470830 3rd Mar 2018 12:29pm
Bennyis01
Thanks for your help peeps, will check cables. I keep getting adaptive dynamics fault but keeps coming and going but changed cables in summer . I didn't realise that this would affect special features mode
Post #470838 3rd Mar 2018 1:30pm
GraemeS
gonna_go_double_r wrote:
I don't think the 3.6 has this but i'm not 100%.
Optional on MY10, standard on MY11/12.
Post #470886 3rd Mar 2018 7:55pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Have you disconnected the battery recently?
The date is wrong.
Post #470889 3rd Mar 2018 8:28pm
he says he has ... ... - .- -.
Post #470890 3rd Mar 2018 8:37pm
Bennyis01
Right guys thanks for all your help I managed to get out side and check cables for suspension struts and as diagnosed one of the legs had a break in it
Once repaired all working and fault free
Many thanks again
A very happy rr driver
Just got to find some snow now
Post #470986 4th Mar 2018 3:51pm
PaulB
Glad it was the easy fix.
Post #471038 4th Mar 2018 7:12pm
