Home > Technical (L322) > My 2006 wont start at all.. Please anyone help..?
Hleo1
2006 Range Rover Vogue SE Supercharged Java Black
Hi, suddenly my 2006 RR vogue spercharged wont start at all - totally dead.. First I thought problem with the battery, but after tried to jumpstart the car also failed.
Landrover mechanic came over to diagnose/reset the computer system. Their computer could not find any "faults" at all, the car's system just wouldnt connect to the mechanic's computer system. They are trying to check the wiring, maybe some problems with electrical issue?
Anyone experienced this before? Any help please...?
Thanks a lot guys..
Hleo1
Post #48832 4th Feb 2011 6:21pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Do you get any lights on the dashboard when you switch the ignition on?
Post #48833 4th Feb 2011 6:24pm
Battery properly connected? (No loose terminals)
Post #48834 4th Feb 2011 6:24pm
you need a pretty hefty battery to start and indeed jump start the RR, i would try again with a more powerful battery... ... - .- -.
Post #48839 4th Feb 2011 6:42pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Sounds like it's a trip to Malayan Motors at Leng Kee Road! Hope they can sort you out without much financial penalty. Smile '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #48850 4th Feb 2011 7:23pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Re: My 2006 wont start at all.. Please anyone help..?
Thanks a lot guys..
Hleo1
Fist thing that springs to mind is that the car doesn't realise it's in Park, I think sometimes the switch in the gearbox can not work properly. Sometimes by shifting it a couple of times it can be made to work again, or it could be a failed component.
Otherwise could it be immobilser transponder? Failure to start would probably be one of these two things if the batteries definitely OK. 2012 SDV8 Vogue SE
Post #48856 4th Feb 2011 8:24pm
Hleo1
No lights at all when turning key ignition Sad
Post #48915 5th Feb 2011 7:46am
Hleo1
Thanks a lot guys..
Hleo1
The mechanic said something like the "Junction block" there is no power electricity at all..?
Post #48916 5th Feb 2011 7:48am
