Home > Technical (L322) > frozen
frozen
Been away for a few days and came back to the car on Heathrow carpark. I had to drive back from Heathrow with no drivers side screen wash, it was working at one point then stopped
Washer system frozen? no water from right hand nozzle onto drivers screen, Im putting it down to weak redymix screen wash at the moment frozen in the pipe to the RH jet. They are supposed to be heated jets so its unlikely to be that. I bought and replaced the drivers side only to find there was a difference. no water out of either side.... and I've just topped up the screen wash..
So tonight it has frozen both sides......
And the bleeding passenger door lock froze in the open position....Kettle of boiling water sorted it out, but most likely it will freeze again..... There is nothing that can't be fixed with a hammer😜😜
Post #470423 28th Feb 2018 8:31pm
steptoe
Halfords sell a selection of -10, -20 and a -30 screen wash
Post #470432 28th Feb 2018 9:03pm
water in the reservoir probably frozen, theres a load of very cold air out there..... ... - .- -.
Post #470435 28th Feb 2018 9:08pm
GGDR
my doors were frozen shut tonight....
. Cheers, Greg
Post #470447 28th Feb 2018 10:08pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
just been out for a play just got in Thumbs Up -5 and jets working just use the ready mix stuff from tesco. think a 4.2 gets very hot tho under the bonnet Very Happy
Post #470449 28th Feb 2018 10:18pm
GGDR
Def fun driving home tonight. So stable - the weight of these things seems to push down on the powdery snow we've got here in London. On a completely safe section got it drifting a little though. 👍😀. Took a bit of encouragement with the throttle but even with me trying to get it to break loose it was not over or understeering very impressed with road holding even under these conditions. Legendary vehicles.
. Cheers, Greg
Post #470451 28th Feb 2018 10:37pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Wish we had enough snow so I could go out to play. What do I put here then?
Post #470457 28th Feb 2018 11:20pm
Have some of ours Thumbs Up
 Got - 2017 SDV8 Autobiography in Loire Blue
Post #470459 1st Mar 2018 12:20am
Happened to me once on the way to a ski holiday - I’ve gone OTT on low temperature screen wash ever since - like -40 or lower rated
Post #470461 1st Mar 2018 12:26am
GAC23
Thank you Alanm_3 What do I put here then?
Post #470467 1st Mar 2018 12:59am
Might get have solutions the frozen door cable, we shall see. Took the little grommet out just above the lock mechanism and doused the insides with WD40. Hopefully this will displace any water causing the mechanism to freeze There is nothing that can't be fixed with a hammer😜😜
Post #470612 1st Mar 2018 9:14pm
Today’s icicle collection Shocked
Post #470615 1st Mar 2018 9:20pm
thats your radiator thats leaking Alan... Twisted Evil ... - .- -.
Post #470622 1st Mar 2018 10:07pm
GGDR
Ok last night the snow was fluffier and it was a bit more fun than tonight.
Came to a junction at 15mph if that - not fast at all, looked like there was grit down - hit the brakes early enough I thought but and the anti lock brakes started juddering and kept juddering pointlessly whilst I kept going like an ice skate - right into the junction.
Luckily the Addison Lee coming at me (who had right of way) saw me struggling and meanwhile I turned the wheels towards the kerb to try to use that to stop me and start pumping the pedal. Stop in the end. Eventually.
So the snow's fine. Just watch out for black ice guys. Shocked Shocked Shocked
. Cheers, Greg
Post #470623 1st Mar 2018 10:29pm
Sandyt
Are you on full winter tyres?
Post #470625 1st Mar 2018 10:34pm
