Home > Maintenance & Mods (L322) > Torque Converter diagnostics Error
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
When I run the diagnostics using my Chinese BMW Scanner (PA Soft 1.4), it reports a torque converter error 5212.
An online search of codes finds just one listing of this code being for low battery voltage, but the battery voltage seems OK. The gearbox (the third in the vehicle) seems OK. There is a tiny weep from the rear TC bearing, but neither garage I have checked with thought it anything to worry about.
I wonder if this is a quirk thrown up by using the BMW scanner on the L322 or whether it points to something serious. Most of the many other fault codes seem to match genuine faults, but most of them provide a text description rather than just a number code.
Does the E53 X5 use the same gearbox and torque converter? Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #469644 22nd Feb 2018 1:12am
