Home > Technical (L322) > Alternator or Starter |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Could be the leads between the battery alt and starter motor - may need cleaning all terminals and reseating |
18th Feb 2018 7:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Could also be earth strap connections from engine block to body. |
18th Feb 2018 7:27pm |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 |
cheers , any easy enough way to check the wiring ? Current Vehicles :
18th Feb 2018 7:30pm |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 |
See thread on Quirky starting. Try the windscreen wiper trick!! 2011 4.4 TDV8 Vogue SE
18th Feb 2018 10:10pm |
I swear to christ if that actually works.... this seems like the most ridiculous thing ever Current Vehicles :
18th Feb 2018 10:18pm |
that is absolute witchcraft , why does that work. Current Vehicles :
19th Feb 2018 10:57am |
Absolutely no idea why it works but this morning I had three attempted starts and three clicks, did the windscreen wiper thing and it started immediately.
22nd Feb 2018 7:36pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 |
Is it not just the same as with lithium batteries in Cold temps ?
23rd Feb 2018 12:35am |
Well when you press the starter button a whole bunch of things fire up including ECUs, glow plugs, TFT screen etc which I would have thought would wake something up even if that theory also applies to AGM batteries. 2011 4.4 TDV8 Vogue SE
23rd Feb 2018 9:08am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
I've searched on "quirky starting" and not found anything.
23rd Feb 2018 10:18am |
It is described in item 2 below
23rd Feb 2018 11:04am |
^ Excellent; thank you!
23rd Feb 2018 12:36pm |
The issue was the starter, now replaced, but rhe wondow washer thing works Current Vehicles :
23rd Feb 2018 1:06pm |
Cheers, Eric. |
23rd Feb 2018 1:49pm |
