Home > Technical (L322) > Alternator or Starter
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Ok so on Tuesday my 2010MY 3.6TDV8 decided it didn't want to start coming out of the supermarket, would just Get a click from the solenoid but no cranking. Got my housemate down to jump start and it worked grand.
Decided to change the battery the next day as its a 2013 battery so just presumed dead, fitted a new Yuasa AGM battery, did the battery reset with my IIDTool and plugged in a ctek charger to fully charge it overnight,
now the range will start (sometimes) and under live values on the IIDTool shows it not losing current, even with every single electrical item on , the car isn't faultering.
The mechanic I'm dropping it to in the morning is determined that its the alternator and wants to remove it, have it checked and probably replace it because its reading 13.7 volts (he's saying it should be 14.5 but its an AGM battery so I'm pretty sure its just in float charging mode) . the alternator out is a much bigger job and more time consuming.
the car will start after 3-4 times on its own usually, sometimes 6-7 times or a jump start (no idea why jumping it works) , I think its a dead segment on the starter.
car has 87000 miles on it if that makes any odds. Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #469216 18th Feb 2018 7:06pm
Sandyt
Could be the leads between the battery alt and starter motor - may need cleaning all terminals and reseating
Post #469220 18th Feb 2018 7:20pm
Could also be earth strap connections from engine block to body.
Post #469224 18th Feb 2018 7:27pm
Eric Cartman
cheers , any easy enough way to check the wiring ? Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #469225 18th Feb 2018 7:30pm
TomCobbly
See thread on Quirky starting. Try the windscreen wiper trick!! 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #469258 18th Feb 2018 10:10pm
Eric Cartman
I swear to christ if that actually works.... this seems like the most ridiculous thing ever Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #469261 18th Feb 2018 10:18pm
Eric Cartman
that is absolute witchcraft , why does that work. Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #469305 19th Feb 2018 10:57am
TomCobbly
Absolutely no idea why it works but this morning I had three attempted starts and three clicks, did the windscreen wiper thing and it started immediately.
It is either witchcraft or dodgy software I reckon Shocked 2011 4.4 TDV8 Vogue SE
Post #469704 22nd Feb 2018 7:36pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Is it not just the same as with lithium batteries in Cold temps ?
The battery needs to see a draw to wake it up . It’s common on bikes to switch headlights on prior to starting a llithium battery equipped bike 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #469738 23rd Feb 2018 12:35am
TomCobbly
Well when you press the starter button a whole bunch of things fire up including ECUs, glow plugs, TFT screen etc which I would have thought would wake something up even if that theory also applies to AGM batteries. 2011 4.4 TDV8 Vogue SE
Post #469759 23rd Feb 2018 9:08am
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
I've searched on "quirky starting" and not found anything.
Could someone explain what the "windscreen wiper trick" is, please as I to occasionally experience the click and no start phenomena and had it in mind to change the starter.
Post #469766 23rd Feb 2018 10:18am
TomCobbly
It is described in item 2 below Thumbs Up
Post #469769 23rd Feb 2018 11:04am
Giantlandyman
^ Excellent; thank you!
Kevin
Post #469776 23rd Feb 2018 12:36pm
Eric Cartman
The issue was the starter, now replaced, but rhe wondow washer thing works Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #469780 23rd Feb 2018 1:06pm
Giantlandyman
Cheers, Eric.
Post #469791 23rd Feb 2018 1:49pm
