Home > Technical (L405) > Tailgate out of alignment, dealer problem |
Aspman Member Since: 09 Mar 2021 Location: Ssotland Posts: 4 |
I'll take a look at that if it's likely to be a regular issue.
18th Mar 2021 3:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
there's a powerfuluk video on youtube that shows you how to do it..the job is a bit fiddly but can be done.. ... - .- -.
15th Jun 2021 2:14pm |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 215 |
thanks stan - i'm all for getting the dealer to handle it if possible especially as I raised a concern under warranty in 2019.
15th Jun 2021 2:36pm |
I paid £140 for 1hr labour to realign.
17th Jun 2021 9:06am |
they're replacing the left and right stays and the left and right hinges which I guess explains some of the cost. probably £600 of parts charge.
17th Jun 2021 9:33am |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 89 |
If you look at most RRs over 3 years old the tailgate has dropped and the chrome strip across the back does not line up with the top of the tail lights.
6th Apr 2022 2:26pm |
The dealer replaced the bolts as per the bulletin today, under warranty which has improved it a tiny bit but they said it needs proper alignment in their bodyshop which is not covered on the warranty...
26th Apr 2022 4:45pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
My tailgate has started to screech a little on closing the upper, should I be worried
26th Apr 2022 8:38pm |
