![]() | Home > Technical (L405) > Tailgate out of alignment, dealer problem |
Aspman Member Since: 09 Mar 2021 Location: Ssotland Posts: 4 ![]() ![]() ![]() |
I'll take a look at that if it's likely to be a regular issue.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
there's a powerfuluk video on youtube that shows you how to do it..the job is a bit fiddly but can be done.. ... - .- -.
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
thanks stan - i'm all for getting the dealer to handle it if possible especially as I raised a concern under warranty in 2019.
I paid £140 for 1hr labour to realign.
they're replacing the left and right stays and the left and right hinges which I guess explains some of the cost. probably £600 of parts charge.
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 92 ![]() ![]() ![]() |
If you look at most RRs over 3 years old the tailgate has dropped and the chrome strip across the back does not line up with the top of the tail lights.
The dealer replaced the bolts as per the bulletin today, under warranty which has improved it a tiny bit but they said it needs proper alignment in their bodyshop which is not covered on the warranty...
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1260 ![]() ![]() |
My tailgate has started to screech a little on closing the upper, should I be worried |
