Home > Technical (L322) > '07 key pairing process
Blair
Received a new key from Dan @ Duckworth's on Saturday, and having a minor issue.
I've used my GAP IID to pair the key to the ignition, so it unlocks the steering and starts the car, but it won't remote unlock or lock the car. Nothing happens when the buttons are pressed.
I've been using the key for the ignition, in the hope it was just a flat battery, but no change.
What have I missed? Have I not paired it correctly?
Post #464753 16th Jan 2018 11:49am
Dano0404
Hello I didn’t buy a new key but after the bat running flat on my car had the same issue and this worked for me.
Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Post #464757 16th Jan 2018 12:43pm
Blair
I'll try that later Smile
Post #464759 16th Jan 2018 1:10pm
Blair
Worked a treat. All sorted now, thanks!
Post #464870 17th Jan 2018 10:04am
SteveRRL322
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Hello Blair
I have been trying to program my spare key with my iidtool but cannot get it to work.
Did you have any problems at all?
Mine will program the main working key fine but when you take it out then put in the spare
Key it does not switch off the steering lock so you cannot turn it to program it. I take it your
new key turned in the lock Straightaway? And did you have to programme it in position 1?
Thanks in advance for any help.
Steve.
Post #464899 17th Jan 2018 2:59pm
Blair
Do you have the IID BT?
Mine gave specific instructions to follow, to pair the keys. I just followed those. I used the working key intially.
Post #465091 19th Jan 2018 11:02am
SteveRRL322
Thanks for the reply,
Yes have the tool and followed the instructions but can you remember when u took out the working key and put in the new one did you have to turn the key to programme it as mine will not turn in the lock?
Post #465103 19th Jan 2018 12:26pm
Blair
I think you have to put it in the lock, press a button on the app, and you'll hear the steering lock open so you can turn the key.
Post #465127 19th Jan 2018 2:44pm
SteveRRL322
I will give that a try.
Many thanks 👍
Post #465129 19th Jan 2018 2:53pm
