![]() | Home > Technical (L322) > Abs module |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
What makes you think you need to code it to your car?
Coffey12 Member Since: 29 Dec 2017 Location: St helens Posts: 6 ![]() ![]() ![]() |
I have i data mis match error/ incorrect coding error when plugged in. 3 amigo’s on all the time also |
What are you using for diagnostics?
I’ve used snap on, icarsoft and had a guy use hawkeye and iid tool. I’ve tried the lock to lock a few times i’ve also calibrated the steering on the diag but none of these will let me code anything unfortunately i have seen posts people having there coded just not seen anyone north west ways . |
It’s odd because when I was looking to replace mine I trawled the BMW forums, most of them said that recoding wasn’t necessary so I went with the majority.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
I think the reader they have at Land Ranger Services at Middlewich can do most things. I've seen them re-code new keys there. Current:
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
If you do invest in PASoft, look at http://www.fullfatrr.com/forum/topic44995.html first. Basically you may need to check the software from China for malware, and the hardware for the correct straps internally and poor soldering. That said, mine is working well as far as I can tell. I haven't tried recoding with it, though. Old 110 2.3 Petrol ???? - ???? Old 110 200tdi ???? - 2004 1996 Discovery 300tdi 2004 - 2015 met fiery end being welded 2004 JEEP Grand Cherokee 2015 - 2017 2004 L322 Td6 2017 - |
