Home > Technical (L322) > Abs module
Coffey12
United Kingdom 2003 Range Rover Vogue Td6 Barolo Black
Abs module
Hi ffrr,
I have recently replaced my abs module for a used one off a similar year model and engined car. I now need the
Module coding but having trouble finding someone or any info on this in my area. I live in st helens north west any help
Would be great
Cheers James
Post #463038 2nd Jan 2018 6:19pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
What makes you think you need to code it to your car?
I replaced mine and didn't need to code it.... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #463055 2nd Jan 2018 7:41pm
Coffey12
I have i data mis match error/ incorrect coding error when plugged in. 3 amigo’s on all the time also
Post #463057 2nd Jan 2018 7:54pm
UK Marine
What are you using for diagnostics?
Have you tried a battery reset and a steering turned fully left and right? ______________________________
Simon
Post #463061 2nd Jan 2018 8:17pm
Coffey12
I’ve used snap on, icarsoft and had a guy use hawkeye and iid tool. I’ve tried the lock to lock a few times i’ve also calibrated the steering on the diag but none of these will let me code anything unfortunately i have seen posts people having there coded just not seen anyone north west ways .
Post #463081 2nd Jan 2018 9:54pm
UK Marine
It’s odd because when I was looking to replace mine I trawled the BMW forums, most of them said that recoding wasn’t necessary so I went with the majority.
Luckily I didn’t have to recode mine but I did find on the BMW forums a program and dongle to do most of the coding in the Range Rover. Have a look for a program called P.A Soft 1.40 it allowed me to code a replacement instrument cluster to my Range Rover.
Have a look on YouTube and go through the BMW forums for any help, tips and instructions - I did and it helped me.
Good luck ______________________________
Simon
Post #463084 2nd Jan 2018 10:52pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I think the reader they have at Land Ranger Services at Middlewich can do most things. I've seen them re-code new keys there. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #463161 3rd Jan 2018 6:47pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
Good luck
If you do invest in PASoft, look at http://www.fullfatrr.com/forum/topic44995.html first.
Basically you may need to check the software from China for malware, and the hardware for the correct straps internally and poor soldering.
That said, mine is working well as far as I can tell. I haven't tried recoding with it, though. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #463226 4th Jan 2018 1:13am
