Home > General > MOT - A-Holes
Page 1 of 3 123>
dan_uk_1984
MOT - A-Holes
MOT place tried to fail my car on left/right brake bias – When I asked them how they knew this because I didn’t see a 4 wheel rolling road they said they tested it on a 2 wheel road. I explained that being perm 4wd this can damage the transmission and any damage caused I would be expecting them to pay for.
I said there is nothing wrong with the brakes, and that the VOSA process for any perm 4wd car is to do a road test and see if it pulls left or right. As mine doesn’t they agreed to pass it.
I should bloody well hope so. Don't mess with my car.
Oh and they slipped in that this wouldn't qualify as a free re-test if I took it away to do the work!
Riverway MOT Centre Trowbridge - Steer clear!
Post #47828 27th Jan 2011 4:13pm
Presumably in Neutral it should be OK on the rollers?
Gary
Post #47830 27th Jan 2011 4:16pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Sure you didnt let them off lightly Dan.
So when i MOT mine i have to find a place with a 4 wheel roller to test the brakes?
edit; seen gaz reply now, neutral ok? 2004 black Vogue TD6
Post #47832 27th Jan 2011 4:19pm
dan_uk_1984
No, neutral is NOT ok...
Your front and rear wheels are always connected via the centre diff, just like left to right, what gear your in has no relevence to the "final drive" section.
I have a copy of the page from the worksop manual to give him for future reference.
Post #47836 27th Jan 2011 4:26pm
just spoke to my boy [mot tester] and he says that you can use a de-accelerometer to test the RR brakes..
this might be useful to someone.. http://www.motuk.co.uk/manual/contents.htm ... - .- -.
Post #47838 27th Jan 2011 4:27pm
Jsb
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Dan: So is the damage done straight away? If so have you noticed anything or did they not even put it on the rollers?
Post #47841 27th Jan 2011 4:28pm
dan_uk_1984
Vehicles not to be tested on a roller brake tester:
Certain vehicles should not be tested on a roller brake tester, e.g. vehicles with
· More than one driving axle permanently engaged
· Limited-slip differential
It's quite simple, the front and rear wheels are always connected. This is the reason you cant tow it with two wheels in the air.
The workshop manual basically says the same as the VOSA info above.
The thing that muddies the water is that the car can be tested on a 2 wheel rolling road IF the propshaft to the axle being tested is removed. Obviously this does not happen in an MOT.
Considering a road test is an acceptable method for testing, I see no reason for the RR to go anywhere near a rolling road.
On top of this, this is also how garages test the Handbrake - another surefire way to screw your tranny if left on for more than a second or two.
Post #47848 27th Jan 2011 5:13pm
I think Scarey meant a road test using a hand held de-accelerometer.... Thumbs Up
Post #47849 27th Jan 2011 5:19pm
dan_uk_1984
Ah, in which case sorry, that would be fine Thumbs Up
No damage detected, however I will be reporting them to VOSA for trying to screw me with the free re-test thing!
Post #47850 27th Jan 2011 5:20pm
Reformed
So glad that the guy that does our MOTs knows his stuff! He used to MOT my 911 Carrera 4. I had similar problems with that car and MOT garages until my friend recommended his mechanic. Reformed
Post #47851 27th Jan 2011 5:30pm
Taken from Scareys link:
The Testers Manual
3.7 Brake Performance (Roller Brake Test)
· Belt-driven transmission
· Brakes for which the servo operates only when the vehicle is moving
These vehicles should be tested using a properly calibrated and maintained decelerometer or a plate brake tester designated as acceptable for the statutory tests, see Sub-Section 3.7B and C.
A roller brake test is also not appropriate for vehicles with damaged, under-inflated or studded tyres.
B. Decelerometer Test
1. If the vehicle is of a type which cannot be tested on a roller brake tester,
· set up the decelerometer in the vehicle in accordance with the equipment manufacturer’s instructions
· drive the vehicle on a level road at a steady speed of approximately 20mph (32kph) and note the brake efficiency recorded when applying only
a. the service brake.
b. the parking brake.
c. while the vehicle is decelerating under the action of the service brake note if the steering wheel tends to pull or the vehicle tends to swerve.
Record the appropriate results of the brake test via the VTS Device. Where the VTS Device is unserviceable see the Introduction section paragraph 3.
Post #47853 27th Jan 2011 5:34pm
dan_uk_1984
By service brake - do they mean the foot brake?
Post #47856 27th Jan 2011 5:53pm
yes Thumbs Up
Post #47858 27th Jan 2011 5:55pm
M44K TS
RE: the Limited slip differential, that would explain why my old Accord Type R didn't get put on the rollers for the front brake test. I always wondered why, I thought he was cutting corners Laughing 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #47860 27th Jan 2011 6:02pm
DAN, i did mean on a road test as GAZ suggested [ta gaz Wink ] its just i didnt listen to my boy properly.. ... - .- -.
Post #47863 27th Jan 2011 6:10pm
Page 1 of 3 123>
