![]() | Home > Technical (L322) > TD6 low drive / snow mode |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7903 ![]() ![]() ![]() |
It’s to select low range on the gearbox. Nothing to do with traction control or any clever terrain response.... 2011 Range Rover Vogue SE 4.4 TDV8
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If you are going to try it , make sure you are on your drive and don’t need to go anywhere for a while...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Chaps I believe the Mountains logo switch is the HDC, not Low range, which from memory is on the passenger side of the tunnel |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
Surely low range is for things like off road and precision heavy towing.
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
I made the mistake of deciding it would be a good idea to try low range to get up to the road from my house in a foot of snow Monday. All worked fine, except it then resolutely refused to go back into high range.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 761 ![]() ![]() ![]() |
Cheers all
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Once or twice a month I will go through the various modes. Hi/lo, Hdc, ride height up and down etc.
