Home > Maintenance & Mods (L322) > Refurb G/Box supplier?
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Ok so after flushing and filter change on my 2004 TD6 the auto box still goes into fail mode when car changes into 5th. Is driveable in Sports and does not go into fault.
Kinda guess it’s time for a refurb Box to be fitted.
Any recommendations and rough price? I’m in Kent/Essex. M25 Jin 1/30 area
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #459576 4th Dec 2017 5:38pm
mr_spock
I just had mine done at A1 Premier in St Neots. Might be a bit of a way but the price was OK, and it drives beautifully now. Just over £2K with the converter. They flow test the oil cooler too and replace if needed.
Post #459622 4th Dec 2017 9:58pm
Boydonegood
Ah ok. Could be an option. Thanks!
Was kinda guessing around £2k.
Not ideal close to Christmas but may have to happen I guess. Oil and filter change didn’t help Accept, some days your the pigeon, some days your the statue!
Post #459652 5th Dec 2017 9:41am
Not super convenient, but if you want it doing properly, then RRPhil is your man Thumbs Up
http://www.fullfatrr.com/forum/topic38676.html
Post #459657 5th Dec 2017 10:37am
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
im sure range rover phil only does the v8 range rover gearboxs not the gm boxes on td6 engines
Post #459659 5th Dec 2017 10:59am
bertie1
iv heard good reports of Suffolk transmissions google them
Post #459660 5th Dec 2017 11:01am
Laughing I thought the exact opposite..... the name of his company is 5hp24 - which is the code for the 5 speed GM box....
Post #459664 5th Dec 2017 11:38am
bertie1
Im pretty sure its only the boxes with the bmw m62 engine ie v8 not td6
Post #459665 5th Dec 2017 11:48am
Boydonegood
Cheers so much guys. Distance isn’t a major issue as it still drives in sport mode.
Will have a shop around and try get some prices as unfortunately that’s gonna play a bit of a role too.
I’m still not 100% convinced box is totally u/s. When it’s in fault mode it makes a noise in D and R and limp mode. Clear the fault with Icarsoft and there’s no noise and pulls and changes ok. It will go back into fault when it tries selecting 5th
Clear the fault and drive it in sport and it drives ok. No noise all day.
So kinda hopeing I can find a company that isn’t just gonna default throw a new box in IF it doesn’t need it. (Although I think it does) Accept, some days your the pigeon, some days your the statue!
Post #459668 5th Dec 2017 12:12pm
bertie1
i do know that when I took my friends fatty with him to Suffolk transmission the guys where great tested everything etc the only thing is its a bit far out but il go there when I get problems forsure good luck hope all gets sorted and doesn't clear out the wallet before Christmas
Post #459677 5th Dec 2017 1:59pm
Boydonegood
Thanks so much.
As say car is driveable so happy to go where needed to get a good job at sensible price and not get ripped off.
Will call them today to get a real ballpark figure.
Thanks
Post #459804 6th Dec 2017 8:42am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
It's the other side of the M25 from you, but STA in Aylesbury (https://www.staautogearbox.co.uk/) have been used by a few people on here including me and have a very good reputation. If I had another full fat, then I would use them or RRPhil.
Post #459805 6th Dec 2017 8:50am
miggit
^^ I second that... And a little secret... if you ask nicely they will fit a brand new torque converter (as opposed to rec) for about £100 more! Well worth doing Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #459806 6th Dec 2017 9:20am
Boydonegood
Oh awesome! Thanks for the info.
The car does drive fine in Sport. Well it Drove back 10mile ok.
I know I shouldn’t be looking to save money but price is going to play a part in where I go. I want to find somewhere that’s been used before, recommended but I also appreciate that pay pennies get monkeys. So I’m gonna have to ring round some you guys suggest.
I’m hopeing it don’t go a million miles over the £2k figure.
Nuts and bolts I’m ok with and would attempt, and 10 years younger I’d be getting under there myself for, but those days are gone now I’m afraid.
Thanks I really appreciate any advise.
Cheers
Post #459807 6th Dec 2017 9:21am
Druboo
England 2005 Range Rover Vogue Td6 Zambezi Silver
I'll third it Very impressed with STA and new converter fitted. Also modify the control block with upgraded control valves and you get a warranty for your hard earned. Thumbs Up
Post #459826 6th Dec 2017 2:48pm
