Home > Maintenance & Mods (L322) > Radiator water temperature
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
In the last couple of weeks my temperature gauge has been struggling to reach the first mark at about 10 o'clock (normally 12 o'clock). A few posts on here say "change the EGR thermostat", so I thought that I should first use my IID tool to check what the actual water temperature is after a 10 mile run. I knew it was cold, but -2736C seemed a little too chilly - sadly, the same value appeared after I cleared all faults.
Has anyone else experienced incorrect values from a water temperature sensor (or have any ideas of where the sensor is located) please?
Post #459552 4th Dec 2017 1:02pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
As Absolute Zero is - 273C, and you seem to have got well below that then I would talk to the good folks at CERN. They would no doubt pay a small fortune for such a vehicle... Laughing
Post #459563 4th Dec 2017 4:22pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
I seem to remember that the thermostat opens at 85c .
I was concerned when I checked mine - it was over 110 thousand c !!!! As that was hotter than the sun I decided that it wasn't very accurate!! lol
On a long downhill run mine cools to the 10 o'clock position then recovers, a replacement thermostat is on the cards when i have the time.
Simon
Post #459571 4th Dec 2017 5:02pm
