Home > In Car Electronics (L322) > Radio stuck on Splash Screen.
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
My 07 Vogue has developed a fault with the audio system, in that in goes no further than the Land Rover splash screen, no mater how long you leave it for.
The display unit is completely unresponsive to button presses, and also the Bluetooth unit isn’t visible to my phone, it is almost like the system isn’t booting up.
It started yesterday evening a couple of hours after I had to jump start the car as I had come out of work to be presented by a flat battery, my little Li-On jump pack started the car fine and the audio system was fine and it was on the next couple of journeys that evening, but on the last journey it just sat at the splash screen and it has done on all the journeys today.
Has anyone got any suggestions ?
Post #459209 1st Dec 2017 6:14pm
Paul thornton
I think there's a fuse you can pull to reset it but not sure which one.
I'm sure somebody will be along in a minute with the correct info.
Post #459215 1st Dec 2017 7:09pm
Jamiehol
From a bit of reading around I think I have a fault on the MOST ring, this is sorted of backed out as I have tried unplugg8ng the MOST connections from the TMC, TV, and Bluetooth and I am not getting a red light.
I will take a look at the amp tomorrow and check all the fuses and do a battery reset.
Post #459220 1st Dec 2017 7:33pm
You could just try disconnecting the battery -ve terminal, leave it disconnected for 5 minutes, reconnect and see what happens.
Post #459224 1st Dec 2017 8:02pm
Jamiehol
Yes think I will give a battery disconnect/reset tomorrow when it is light. Certainly easier than removing modules to get to the amp.
Post #459225 1st Dec 2017 8:08pm
Jamiehol
So got the audio system working again today.
I tried a battery reset but that didn’t seem to make any difference, so I decided to eliminate devices on the MOST ring, I started with the iPod adapter and CD changer when I removed the changer from the breakout on the iPod adapter and put a loop in place everything work.
What is more odd I removed the loop and then everything still worked so who knows what fixed it but it is working again which is the main thing Smile
Post #459349 2nd Dec 2017 5:43pm
