![]() | Home > In Car Electronics (L322) > Radio stuck on Splash Screen. |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I think there's a fuse you can pull to reset it but not sure which one.
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
From a bit of reading around I think I have a fault on the MOST ring, this is sorted of backed out as I have tried unplugg8ng the MOST connections from the TMC, TV, and Bluetooth and I am not getting a red light.
You could just try disconnecting the battery -ve terminal, leave it disconnected for 5 minutes, reconnect and see what happens. |
Yes think I will give a battery disconnect/reset tomorrow when it is light. Certainly easier than removing modules to get to the amp. |
So got the audio system working again today.
