![]() | Home > Technical (L322) > auxiliary heater |
northernmonkey Member Since: 30 Jul 2017 Location: Teesside Posts: 14 ![]() ![]() ![]() |
My 2012 Westminster does the same, all info I can find points to it being the aux heater, its seems that it uses that to heat the cabin while the engine gets up to temp, then it turns off. I agree it sounds a bit on the loud side but that seems common/standard. 2012 westminister Overfinch Obsidian Conversion |
westminster 62 Member Since: 03 Oct 2017 Location: essex Posts: 20 ![]() ![]() ![]() |
Many thanks, I did think the same, just wanted to make sure, didn't want to ask dealer as they they would probably say bring it in and charge me a fortune to tell me it is normal. |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
All normal, my TD6 Vogue does the same, depending on the outside temp. On cold mornings my FBH fires up to assist rapid warming of the cabin and engine. Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
Many thanks. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
I think the temperature is 16c for oil burners and 1c for the petrols that have it those are outside temps and when they are those or below it kicks in to assist heating cabin |
Many thanks. |
roverron Member Since: 16 Apr 2009 Location: Londerzeel Posts: 86 ![]() ![]() ![]() |
My MY 2012 has since a few months also this humming noise, at first I also thought it could be the FBH. If it is coming from it, wat could be the cause? This noise is irritating and not normal.
It is definitely coming from the FBH!
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Westminster,
Thanks for the info Richard,
Hi Ronald
I've been thinking |
Nismotec Member Since: 27 Apr 2019 Location: Dorset Posts: 54 ![]() ![]() |
what was the outcome of this noise? i have a similar noise from my fbh pump/fan in the wheelarch area..... |
spanielzrus Member Since: 20 Aug 2019 Location: Dunfermline Posts: 8 ![]() ![]() ![]() |
Don't know if this helps or not but noise seems to be a known fault by Land Rover and a Tech Bulletin was issued in 2006 regarding the air intake of the FBH.
