Home > Technical (L322) > auxiliary heater
westminster 62
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
auxiliary heater
Hi everyone, when I drive my Range Rover from cold there is a really loud humming noise coming from somewhere near the car battery area, when I switch the engine off the noise carries on for a few minutes, the noise disappears once the engine is warm, I assume the noise is the auxiliary heater, is it normal for it to run when actually driving the car (4.4tdv8)?
I assumed it only works when set up from timed heating menu to warm the car up prior to driving.
Post #457451 16th Nov 2017 1:01am
northernmonkey
My 2012 Westminster does the same, all info I can find points to it being the aux heater, its seems that it uses that to heat the cabin while the engine gets up to temp, then it turns off. I agree it sounds a bit on the loud side but that seems common/standard. 2012 westminister Overfinch Obsidian Conversion
Post #457485 16th Nov 2017 12:10pm
westminster 62
Many thanks, I did think the same, just wanted to make sure, didn't want to ask dealer as they they would probably say bring it in and charge me a fortune to tell me it is normal.
Post #457487 16th Nov 2017 12:15pm
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
All normal, my TD6 Vogue does the same, depending on the outside temp. On cold mornings my FBH fires up to assist rapid warming of the cabin and engine. Late 2004 FFRR Vogue 3.0 TD6 Tonga Green
Previous cars
Series 3 V8 conversion
1989 V8 classic Vogue
1992 V8 Classic Vogue
1998 P38 DSE
Post #459261 2nd Dec 2017 4:47am
westminster 62
Many thanks.
Post #459350 2nd Dec 2017 6:58pm
Sandyt
I think the temperature is 16c for oil burners and 1c for the petrols that have it those are outside temps and when they are those or below it kicks in to assist heating cabin Thumbs Up
Post #459407 3rd Dec 2017 9:33am
westminster 62
Many thanks.
Post #459538 4th Dec 2017 12:22pm
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
My MY 2012 has since a few months also this humming noise, at first I also thought it could be the FBH. If it is coming from it, wat could be the cause? This noise is irritating and not normal.
But now with temperatures rising it still makes that noise after a cold start ( +10° C).
It disappears with the engine getting warm.
If a turn e.g. the right temperature knob from max to min the noise sounds different/ stops and comes back.
I also have the impression that the blower is not responding as fast as it should do?
Could it be the “famous” FSR? Anyway it is a kind of electric humming….
I will start the FBH tomorrow morning ( it will be cold coming night) with the remote to see if the noise is coming from it or not.
Ronald RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #510866 4th Apr 2019 12:26pm
roverron
It is definitely coming from the FBH!
Now with the engine not running, what a noise!
So, one question remains: what is the cause?
And will it break down in the near future if nothing is done?
Perhaps I will disable it, taking the fuse out.
Must be in the engine room somewhere, under the glovebox is no fuse for the FBH. RR 2012MY TDV8 AB ipanema sand
Post #510946 5th Apr 2019 7:23am
rjff
Westminster,
Have a read of the operating parameters posted by MJDronfield in this link.
https://www.fullfatrr.com/forum/topic50325...p;start=15
It should give you the information on when and how the FBH operates.
Roverron
The FBH will run, IIRC, below 16C or until the engine coolant temperature reaches a preset point.
The other noise you refer to could be the FSR, lots of info on here if you search. Cheers
Richard
Gap IIDBT
Post #510975 5th Apr 2019 10:21am
roverron
Thanks for the info Richard,
With humming noise I mean really abnormal noise.
I know how much noise a normal working FBH produces.
What I'm experiencing is 10 times more in volume and height.
And after the test this morning with only the FBH running, this extreme noise is definitely comming from the FBH.
So the FBH works normal, it heats, starts and stops as I command it to do, but this terrible abnormal noise gets me **up
I think it must be the blower that takes cool air in and drives the burnt fumes out?
Is there acces to, only removing the inner wheel fender and spray some WD40 on it, or....
taking battery out en the FBH itself.
Thanks spring and summer with higher temperatures is coming up!
Post #511006 5th Apr 2019 2:45pm
rjff
Hi Ronald
That does not sound good at all. I agree the noise may well be the fan, although there is also a pump in the unit for circulating the coolant. I don't expect you'll be able to access the parts to WD40 without removing the FBH, which is a job that includes at least a part drain of the cooling system, with all the hassle that means. Cheers
Richard
Gap IIDBT
Post #511038 5th Apr 2019 5:22pm
rjff
I've been thinking Confused you have a PM. Cheers
Richard
Gap IIDBT
Post #511040 5th Apr 2019 5:30pm
Nismotec
what was the outcome of this noise? i have a similar noise from my fbh pump/fan in the wheelarch area.....
Post #540818 16th Jan 2020 10:02pm
spanielzrus
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Don't know if this helps or not but noise seems to be a known fault by Land Rover and a Tech Bulletin was issued in 2006 regarding the air intake of the FBH.
My 2006 TD6 also makes this noise and ill be investigating it soon.
I posted images of the bulletin on the following link.
https://www.fullfatrr.com/forum/post546786.html#546786
Post #546809 11th Mar 2020 4:50pm
