![]() | Home > Wheels & Tyres > 22" All Terrain |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Those wheels probably wouldn't be much use off road anyway. No sidewall. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
There are not any 22" AT tyres of any useful size for a RR, trust me I spent a load of wasted time researching this. Non available for 21" either. The Only options are either 275/45/20, 255/55/20 or 285/50/20, definitely no useable 22" out there. I bought a 2nd set of wheels in 20" for the winter / shooting season 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
Unnecessary quote removed
Does anyone know if a set of 20" Sport wheels would be a direct fit on a Full Fat. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35521 ![]() ![]() |
yes they would ..they will be 9.5j so make sure the tyre you fit will accommodate this rim size..
Thanks for your reply |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
Which generation Sport? Offsets are different. |
A 2011 model |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 ![]() ![]() |
You can run a 305/40R22.
Can you let me know what make the tyres are please. |
Matlandy, they are Nitto Terra Grapplers |
Cam-Tech-Craig, the front inner fender liners had to be adjusted. No trimming required, but slight remolding with heat gun to provide more clearance. Depending on wheel offset, some people have to heat up and remold the right rear fender liner where the fuel filler bulge is. |
The only issue with the 305's is the rolling radius is quite a bit larger than standard for an L322, it will lift your top speed but reduce your acceleration as it overgears it slightly (if that really matters) see the chart below which compares standard oe fit 20" to the 305's. The LTZ has also been discontinued in the UK due to EU regs which is a massive shame. It has been superceeded by the Cooper AT3 Sport - not sure if this is available yet in that size. May be worth giving Cooper UK a ring as they are very helpful - ditto Silverline their main distributor.
