Home > Maintenance & Mods (L322) > egr coolant hose leak
marks
United Kingdom 2003 Range Rover SE Td6 Zambezi Silver
hi I have a leak on what looks like the egr cooler hose between rad fan and engine 03 reg td6 I can see the jubilee clip but how on earth do you get to it !! regards
Post #456468 7th Nov 2017 3:13pm
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Hi marks just done my o ring on the egr cooler and you have to remove the viscous fan and cowling then the front engine cover to get egr cooler Thumbs Up
Post #456474 7th Nov 2017 4:29pm
Interestingly, a couple of months ago I replaced the egr cooler and the offending hose jubilee clip by simply removing the front top engine cover. It is a bit compact but it can be done without a lot of dismantling. I used a small ratchet and socket on the jubilee clip. Thumbs Up
Post #456479 7th Nov 2017 5:48pm
marks
ok thanks
Post #456560 8th Nov 2017 4:34pm
marks
thanks will give it a go or two bottles of kseal !!
Post #456561 8th Nov 2017 4:35pm
wayneg
You can scrap the whole egr assy including the cooler by fitting an egr delete unit, blank for the exhaust manifold and 2x hose blank off's which I think are 15mm bore 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #456750 10th Nov 2017 9:00am
Paul thornton
Do you need to have the ecu remapped if the egr is removed?
Post #456752 10th Nov 2017 9:27am
wayneg
On a TD6 no, just plug the vacuum hose. The best thing you will do for your car, the engine will love you for it 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #456755 10th Nov 2017 9:41am
Paul thornton
I could do with changing my thermostat so whilst in that area I may as well do the EGR delete as well I suppose.
Post #456761 10th Nov 2017 10:39am
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mine is gone I took it out at the beginning of the year
Post #456777 10th Nov 2017 12:18pm
Paul thornton
Are you running with no viscous fan as well?
I think I spy the thermostat housing from your pic Very Happy
Post #456788 10th Nov 2017 12:54pm
Joncey
Yes I took the fan off there are a few people on here that run without it seems fine
Post #456802 10th Nov 2017 2:32pm
Paul thornton
Tempted to loose mine as well tbh. The noise it generates is horrendous.
Problem with my car is it over cools.
Now winter is here, the temp gauge never reaches the halfway mark unless you're nailing it up a hill then the centrifugal fan kicks in and cools it right back down again!
They have electric fans as a back up anyway don't they,
Post #456806 10th Nov 2017 2:48pm
marks
its had the egr by pass and a re map it pulls like a train going to look at the bungs like you said thanks
Post #456830 10th Nov 2017 6:07pm
@ Paul thorton
You have a thermostat problem - main and probably the EGR stat too.
A TD6 should reach operating temperature and stay there. .
Post #456833 10th Nov 2017 7:02pm
