Home > Technical (L322) > Strange Happenings Today...
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Went to get the Sunday papers this morning. All fine on outward drive. Got back into the car at the paper shop, turned ignition on and the Hazard flashers started.
Thought I must have pressed the button inadvertently, so turned them off. Drove away and then noticed the interior lights were on. Definitely didn't switch them on! So switched them off.
Back home tried to lock the car. Chirp sounded but locks did not engage. Eventually after several tries, locks did engage.
Fired up my IID tool, but no error codes thrown.
All very strange.
Gremlins do you think?
Post #454991 22nd Oct 2017 11:46pm
It thought you had an accident! Hence the hazards & not locking (obviously if your injured inside)
Battery volts during starting cycle??? How old is said battery?
Post #454994 23rd Oct 2017 12:05am
Gyre8
@ CTC. Battery is 3 Months old. Voltage displayed at 14.4 volts on BT IID Tool.
Post #454996 23rd Oct 2017 12:12am
holidaychicken
Aren't the interior lights on a normal mechanical switch ?
Could you have left them on which drained the battery a bit causing your other gremlins ?
The 14.4 volts , was that with the engine running and the voltage is actually the alternator output?
If none of the above I would call a priest ... Smile
Post #454998 23rd Oct 2017 1:11am
Sandyt
I think the alternator varies output to match load / charging requirement mine shows between 13.7 and 14.5 it varies new alternator and new battery - it shows more if the battery is low might be worth checking. What does it show first thing in the morning before start up?
Post #455006 23rd Oct 2017 5:49am
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I've had the same thing occasionally, just posted about it last week, no definitive cause or cure, but the FF thinking it was in an accident was also suggested.
http://www.fullfatrr.com/forum/topic44903.html
Post #455031 23rd Oct 2017 1:46pm
i've read some where that it could be a to sensitive inertia switch causing this... ... - .- -.
Post #455036 23rd Oct 2017 2:19pm
Gyre8
Thanks Hamlet. exactly the same thing. Car running normally today (so far!).
Voltage this morning with engine not running was 11.8 Volts. Think this is OK.
I await the next worrying glitch. Confused
Post #455039 23rd Oct 2017 3:34pm
Sandyt
|Mine shows 12.5v when not running if that helps
Post #455057 23rd Oct 2017 6:41pm
Rambles
11.8 volts is not ok
Far from it
Post #455060 23rd Oct 2017 6:52pm
Gyre8
If 11.8 volts (engine not running) is not OK, what should it be? How far off is it?
Post #455065 23rd Oct 2017 7:41pm
Sandyt
Fully charged automotive batteries should measure at 12.6 volts or above. When the engine is running, this measurement should be 13.7 to 14.7 volts.
Post #455066 23rd Oct 2017 7:44pm
Sandyt
State of Charge Voltage
100% 12.7 - 13.2
75% 12.4
50% 12.2
25% 12.0
Discharged 0 - 11.9
Post #455068 23rd Oct 2017 7:47pm
Gyre8
Ok. Thanks Sandyt. Mine shows 14.4V running - so that's OK. But it does seem a tad low when not running. It's going in the main LR dealer soon for an MOT. I'll get them to look at it.
Post #455069 23rd Oct 2017 7:49pm
Sandyt
Don't leave it too long as a duff battery will eat your alternator and they are circa 700 quid Shocked
Post #455088 23rd Oct 2017 10:18pm
