Home > Technical (L322) > Strange Happenings Today... |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
It thought you had an accident! Hence the hazards & not locking (obviously if your injured inside)
22nd Oct 2017 11:05pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
@ CTC. Battery is 3 Months old. Voltage displayed at 14.4 volts on BT IID Tool. |
22nd Oct 2017 11:12pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Aren't the interior lights on a normal mechanical switch ?
23rd Oct 2017 12:11am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
I think the alternator varies output to match load / charging requirement mine shows between 13.7 and 14.5 it varies new alternator and new battery - it shows more if the battery is low might be worth checking. What does it show first thing in the morning before start up? |
23rd Oct 2017 4:49am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I've had the same thing occasionally, just posted about it last week, no definitive cause or cure, but the FF thinking it was in an accident was also suggested.
23rd Oct 2017 12:46pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
i've read some where that it could be a to sensitive inertia switch causing this... ... - .- -.
23rd Oct 2017 1:19pm |
Thanks Hamlet. exactly the same thing. Car running normally today (so far!).
23rd Oct 2017 2:34pm |
|Mine shows 12.5v when not running if that helps |
23rd Oct 2017 5:41pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
11.8 volts is not ok
23rd Oct 2017 5:52pm |
If 11.8 volts (engine not running) is not OK, what should it be? How far off is it? |
23rd Oct 2017 6:41pm |
Fully charged automotive batteries should measure at 12.6 volts or above. When the engine is running, this measurement should be 13.7 to 14.7 volts. |
23rd Oct 2017 6:44pm |
State of Charge Voltage
23rd Oct 2017 6:47pm |
Ok. Thanks Sandyt. Mine shows 14.4V running - so that's OK. But it does seem a tad low when not running. It's going in the main LR dealer soon for an MOT. I'll get them to look at it. |
23rd Oct 2017 6:49pm |
Don't leave it too long as a duff battery will eat your alternator and they are circa 700 quid |
23rd Oct 2017 9:18pm |
