Home > Technical (L322) > thoughts
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
thoughts
I have a problem in the winter, if im at an intersection turning left and road is icy sometimes the car car just wont turn. This happens with or without snow tires, accelerating or slowing doesn't matter. In the end I will come to a complete stop then try again. Does anyone have any theories? I can only think either excessive toe in or rear diff staying locked. I dont have excessive tire wear. Anyone else have this problem? my wifes LR3 seems way better turning on ice. Guess maybe a four wheel drive problem with no power going to front wheels is possible.. Antilock brakes dont come on when this happens either.
Thank You
Post #454941 22nd Oct 2017 4:37pm
holidaychicken
Diff as you say or traction control maybe, do you have any fault codes stored?
Post #455000 23rd Oct 2017 12:16am
vitola231
no faults, it does kinda feel like a posi in the back when trying to turn. When I use terrain response it does show rear diff unlocked. If I select snow program its much much worse on ice Very Happy The back end never kicks out though, first car was a 72 road runner with a posi and remember it was very easy to have back end kick out on ice. Thanks for response.
Post #455038 23rd Oct 2017 1:40pm
holidaychicken
I';m not sure really, we don't get ice here any more, I notice you are in London Canada and not London as in 30 miles away from me. Very Happy
I don't know how much is electronic on the later models, mine is a 2004 so I don't have much electronic traction control going on i don't think.
Where you say you have no faults, what did you scan it with ?
Maybe give it a good blast about on some slippery mud forcing the traction control into having something to think about.
Post #455055 23rd Oct 2017 5:39pm
Sandyt
I had nearside upper rear bush worn and it was giving me rear wheel steer but that was noticeable on dry roads so might not help
Post #455056 23rd Oct 2017 5:39pm
holidaychicken
A four wheel alignment check wouldn't hurt then in that case, it is all adjustable at the rear if it's the same as mine
Post #455059 23rd Oct 2017 5:41pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Steering angle sensor? Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #455112 24th Oct 2017 8:30am
