Home > Technical (L322) > thoughts |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Diff as you say or traction control maybe, do you have any fault codes stored? |
23rd Oct 2017 12:16am |
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 |
no faults, it does kinda feel like a posi in the back when trying to turn. When I use terrain response it does show rear diff unlocked. If I select snow program its much much worse on ice The back end never kicks out though, first car was a 72 road runner with a posi and remember it was very easy to have back end kick out on ice. Thanks for response. |
23rd Oct 2017 1:40pm |
I';m not sure really, we don't get ice here any more, I notice you are in London Canada and not London as in 30 miles away from me.
23rd Oct 2017 5:39pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2254 |
I had nearside upper rear bush worn and it was giving me rear wheel steer but that was noticeable on dry roads so might not help |
A four wheel alignment check wouldn't hurt then in that case, it is all adjustable at the rear if it's the same as mine |
23rd Oct 2017 5:41pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Steering angle sensor? Alex
24th Oct 2017 8:30am |
