Home > Technical (L322) > L322 - 4.4 V8 Vogue - Trip Computer Constantly Resetting
piemuncher
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi All,
I have been a member on here in the past, but have forgotten my username and password and it was linked to my old work email address.
So...
I little about me. Keen car DIY'er, have a L322 2004 4.4 V8 Vogue on LPG with 145k miles on it. We do 15-20k a miles in the car and have done for the last 3 years or so. I've also got a BMW Z4M roadster, as well as an Alfa Romeo GT Junior 1600 from 1973 and a few classic Vespa and BMW motorbikes.... I like my old things...
Anyway, to the matter at hand:
As much as I love the car, it's starting to bring up some electrical gremlins. For some reason, I can deal with mechanical quirks, but electrical gremlins Censored me off something rotten - mechanicals can be fixed, electricals I try to ignore but these are now getting to me.
None are terminal (at this stage), but one is particularly annoying...
This all started when I changed a coil 2 years ago. It's a pretty simple operation as everyone knows, and I was sure to disconnect the battery etc.
Anyway, on recommission the car developed an annoying issue of if I put the key in, turned to ignition, removed the key, reinserted, turned to ignition the following happens:
1. The Temperature reading would swap from Celsius to Fahrenheit (and Fahrenheit to Celsius the next time). I'm getting the hang of Fahrenheit as a result, but it's really really annoying.
2. It would reset its trip computer. I am also unable to reset the trip by pressing the stalk (ie, I press it and it does nothing). It's not good for my OCD nature of recording how far I get on each LPG tank.
So far I have replaced the battery and run a plug in diagnostic (Icarsoft I930) but other than a MAF issue and various other codes as a result of the previous weak battery, I can't see an issue.
I'm not scared to throw money at a new ECU if that's what it needs, but I just want it to work!
Help me! Please!
Will
Post #464119 11th Jan 2018 8:49am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Have you had the dashboard/instrument panel out -I would have thought it will be a loose or corroded connection somewhere.
I'd check the connections there on the back of the instrument panel and the back of the screen - also check the electrical boxes under the seats aren't damp or have corroded connections - sorry can't remember which box is where which controls what, but someone will be along in a bit who will know. Also check the rear electrical cubby hole on the left side of the boot isn't full of water and check those connections too - just for peace of mind.
Good luck, be patient and work systematically, you should find it Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #464121 11th Jan 2018 8:58am
