Home > Technical (L405) > "click" noise from pillar
andyravenna
Italy 2015 Range Rover Autobiography SDV6 Indus Silver
Hello All,
I own a MY2015 L405 TDV6-AB. So far I'm very satisfied and I'm planning to keep it for a few years more.
My only problem is a repetitive "click" noise that comes from "somewhere" in the pillar, very close to the driver's hear.
I don't speak English perfectly so I don't know if "click" is the right word to describe this noise, but actually it sounds exactly like when you click on a PC mouse.
This noise is intermittent, and it becomes more frequent when the road surface isn't good. Also, it's more frequent at low speed, when cornering or manouvering. When I drive at highway speed it disappear.
I've tried to remove the panels around the seat belt, the gasket around the door, trying to find the source... but I can't reproduce the noise and I had no effect at all.
When I've asked the dealer and the service tech, they both told me that they are not able to identify the cause.
Am I the only one with this problem?
Post #455495 28th Oct 2017 1:54pm
pld118
Could it be a slightly loose rear, gloss D pillar trim (near the boot), rattling... Or another piece of external trim?
Have you tried putting your hand on external trim pieces to see if they have any movement?
Post #455496 28th Oct 2017 1:59pm
andyravenna
Yes I've been trying to put my hands everywhere in the area, touching the various trim pieces, but I'm not able to stop or reproduce the noise.
It looks like it comes from "inside" the pillar, near the driver's head, just under the area where the seat belt comes out.
It doesn't change if you move the seat belt attachment point up and down.
At a certain point I suspected that there was someting loose inside, but when I've removed the trim pieces I didn't find anything!
A true X-file!
Post #455497 28th Oct 2017 2:07pm
pld118
Ours has got a bot of a creak on the dash board... Annoying aren't they Thumbs Up
Post #455499 28th Oct 2017 2:22pm
dfulgo
Italy
...mine does a "geiger counter"_like noise from the pano-roof BUT only between 15 to 20�C. of outside temperature and after several attempts by the dealer under warranty..., ...I learnt to live with it.., ...annoying anyway... 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue)
Post #455592 29th Oct 2017 10:24am
