Home > General (L405) > Stolen !!!
Page 1 of 5 12345>
Charlyfarly
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Stolen !!!
Hi all,
My lovely RaRa was stolen from my drive less than 40 minutes ago.
It happened around 2.06am.
InControl rang me to let me know.
Plod called but no visit yet.
I have both keys with me so how????????
I'll let you know of developments.
Bastards. If it ain't broken, fix it till it is.
Post #442369 23rd Jun 2017 1:46am
Charlyfarly
Update 3.32am.
InControl have a location for the vehicle but won't tell me where...they will only tell plod!
Off back to bed now.
Bastards.
Regards,
Tony If it ain't broken, fix it till it is.
Post #442370 23rd Jun 2017 2:33am
GGDR
Sorry to hear!
Usual method is they use a repeater to pick up a signal from your keys. If your keys are near your front door they can hold the repeater against your door or window.
http://www.dailymail.co.uk/news/article-44...0-BMW.html
. Cheers, Greg
Post #442374 23rd Jun 2017 6:10am
sorry to hear this...
keep us up to date chap... ... - .- -.
Post #442375 23rd Jun 2017 6:15am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Sorry to hear your news but glad that they think they have located it. Did in control wake you up to say it had been stolen and if so how did they know it was not you driving. Not sure about them refusing to tell you where it was, he who pays the piper calls the tune.
I had also seen a clip of scrotes holding a receiver against the house and we have changed where we keep the keys. letters not necessarily in the right order
Post #442378 23rd Jun 2017 6:58am
Charlyfarly
gonna_go_double_r wrote:
Sorry to hear!
That sounds about right.
Both keys were in our bedroom but near a window.
The tracker people have told me that they got a "tamper" message when the car was about 10 mins from my home. I assume that's because the key fob was not present.
They tell me that the tracker is no longer working (been disabled?) but they may be able to do some sort of GSM triangulation once they have the necessary data protection permissions from me and the local plod.
Sadly, I suspect my beloved car is gone for good. If it ain't broken, fix it till it is.
Post #442379 23rd Jun 2017 6:59am
i suspect you wouldnt want it back even if they found it.... ... - .- -.
Post #442380 23rd Jun 2017 7:05am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Sorry to hear that.
Keep us updated.
Hopefully it is not a long drawn out process to get remedied for you.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #442381 23rd Jun 2017 7:26am
Dixy
Presumably the tamper is them disconnecting the tracker, how can it be that easy? letters not necessarily in the right order
Post #442383 23rd Jun 2017 8:02am
caymanblack
United Kingdom 2017 Range Rover Autobiography SDV8 Carpathian Grey
Scum bags. Unbelievable how easy it can be , keep us informed and good luck.
Post #442386 23rd Jun 2017 8:48am
charlie croker mk2
OP Sorry your car has been stolen . Can we presume from this that the location of the standard tracker is out in the open ?
Did they follow you home ?
Post #442387 23rd Jun 2017 8:59am
CUE99T
ah Censored ....
As long as you and anyone with you are safe then that's all that matters. Cars can be replaced lives cannot sadly.
Be interested to hear the outcome.
Gonna hide my keys now so thanks for the info! all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #442392 23rd Jun 2017 9:24am
charlie croker mk2
If you put your keys in a tin or metal box it acts as a faraday cage and should stop the "key repeater" thefts . Still trying to think of a solution when you have the key in your pocket . My Yamaha tmax key has a on / off button on the fob so as you walk away you can switch the fob off , something for the next model !!!
Post #442396 23rd Jun 2017 9:40am
Rob99
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Thieving fu Censored rs Mad Mad
Could they not have disabled the vehicle remotely when they realised it was stolen and knew where it was. My very basic tracker has an option to cut fuel supply etc which at least stops them getting too far.
Hope it works out for you Thumbs Up 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #442404 23rd Jun 2017 10:41am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
@CUE99T
Very true. It could have been a lot worse.
@ Charlyfarly
I hope this resolves itself and doesn't cause too much aggro. At least you're able to tell us the story rather than us read about something horrific in the newspapers. Thumbs Up
regards
John
Post #442409 23rd Jun 2017 11:14am
Page 1 of 5 12345>
