Home > General > Door handle
slim_sane
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Door handle
Ok sorry folks first post and it's a question! But I know you'll be able to help Bow down
I just joined the club and bought a FFRR after previously having a RRS. Anyway I have a problem with the passenager side door handle the cap seems very loose and moves around and the whole handle feels like it's going to come off in your hand if you yank it too hard. Has anyone encountered this before?? Any way I can try and fix this without having to take the door card off?
All help greatly appreciated!
Post #46451 18th Jan 2011 8:38am
dan_uk_1984
Is it a standard/genuine handle as far as you can see? No one's stuck on a nasty chrome cover etc?
D
Post #46452 18th Jan 2011 8:53am
slim_sane
Nope, no covers etc genuine handle as far as I can tell!
Post #46454 18th Jan 2011 9:11am
door card does have to come off ...its a bit fiddly to get it back on mind.
Post #46471 18th Jan 2011 11:00am
daveo
HI the cap has a screew(torx) that is accessed from the door shut, it is covered by a rubber grommit, but with the handle, is it just the the handle that is loose or the hole unit handle and backing, V8 facelift Range Rover Autobiography 22" wheels.
Post #46502 18th Jan 2011 5:23pm
slim_sane
It's the whole handle unit that is loose, I have changed the handles on my old RRS so was looking for that screw, but couldn't see it, although it was pretty dark, I'll have another look when I get home tonight and see if I that sorts it. Otherwise I guess it's door card off time, great! Big Cry
Post #46512 18th Jan 2011 6:08pm
daveo
if its the cap it can be tightened as long as its not damaged , the handle unlike the sport you have to remove the whole unit from inside the door, that means you will need to take the door card off and you will be able to see the bolts, the door card is not hard at all 3 screws V8 facelift Range Rover Autobiography 22" wheels.
Post #46543 18th Jan 2011 9:13pm
slim_sane
I got home fairly late last night, but still wanted to try and tighten the cap screw as this would be an easy fix. Anyway the freezing conditions last night didn't help as the door was frozen shut, once I managed to open it, found the screw and tighten as best I could and it seemed to do the job, I think over the weekend I'll have a proper look when it's not 0 degrees and pitch black! Thanks again for all your help. Bow down
Post #46597 19th Jan 2011 9:52am
Good job in those conditions!
Post #46599 19th Jan 2011 10:45am
