![]() | Home > Maintenance & Mods (L322) > Side steps |
Roadking Member Since: 03 Sep 2017 Location: West of Scotland Posts: 38 ![]() ![]() ![]() |
Hi there,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35496 ![]() ![]() |
you're not the only one that has had problems with the roof button,mine doesnt seem to do what it says in the manual..
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 ![]() ![]() ![]() |
I e had limited success with this set of instructions. By limited I mean I managed to get one step to lock out but not the other.
I've been out to the car again and had another look at the manual. I managed to put them into roof access mode and switch them off and back on again. Progress |
@Roadking
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
The button doesn't activate the steps.
To get into roof access, turned ignition on to first stage, no engine start, then pressed the roof button for 3 secs. Mistake I was making was pressing roof button too soon. Lock position was turn on ignition while holding the roof button and watch for the flashes. Do you have the instructions? If not I can copy the page and post. |
@Roadking
Ok, I'll stick a photo on tomorrow. |
Manual as requested. I tried the lock out this morning and when switching ignition on I didn't need to actually start the engine. Just first stage. Also, wait a bit when you get in before you start the switching. Let the car settle for a minute.
you can view/download these instructions from the topic site... ... - .- -.
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Stan, do you mean jack from an appropriate place behind the wheel? __
indeed |
Mike - Many Thanks |
