Home > Maintenance & Mods (L322) > Side steps
j_rov
Side steps
Greetings all,
I fitted the deployable side steps at the weekend, which was fairly straightforward once I'd figured out how to remove the interior trim without damaging it and clearing 7 years of crud out of the chassis bolt holes.
They work when you unlock and lock the car, or when you open a door, however nothing seems to happen when I press the new button which was fitted by the sunroof control. The instructions were for a <MY10 so I'm wondering if the sequence they showed in the instructions (ignition, hold 1 second, ignition off hold 5 seconds) is different for >MY10, which mine is?
Also, is it permissible to jack from the chassis rails now that the jacking points are obscured by the steps? Obviously with appropriately jack...
Cheers __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #451283 18th Sep 2017 12:44pm
Roadking
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Hi there,
I had mine fitted by the dealer before I collected the car last week. Likewise, I haven't managed to get the roof access working via the roof button yet. However, with regards to using the Jack, the manual states the boards should be removed first by undoing the 4 alan bolts using the key supplied with the kit.
Regards
Mike
Post #451315 18th Sep 2017 6:09pm
you're not the only one that has had problems with the roof button,mine doesnt seem to do what it says in the manual..
as for jacking, you remove the step runners and jack up on the jacking points or leave the steps on and jack each wheel from the front and rear.. ... - .- -.
Post #451326 18th Sep 2017 7:17pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I e had limited success with this set of instructions. By limited I mean I managed to get one step to lock out but not the other.
Sitting in the car
1. Press the unlock button on dash to make the steps come out.
2. Whilst they are out press and hold the overhead button and start the car.
Post #451329 18th Sep 2017 7:27pm
Roadking
I've been out to the car again and had another look at the manual. I managed to put them into roof access mode and switch them off and back on again. Progress Very Happy
Post #451330 18th Sep 2017 7:46pm
millerj90
@Roadking
What method did you use?
Post #451348 18th Sep 2017 8:55pm
The button doesn't activate the steps.
It locks the steps in the position they are in.
So if you open both doors so the steps deploy press the button until the light comes on then they stay out until the button is pressed until the light goes off. There is nothing that can't be fixed with a hammer😜😜
Post #451352 18th Sep 2017 9:17pm
Roadking
millerj90 wrote:
@Roadking
To get into roof access, turned ignition on to first stage, no engine start, then pressed the roof button for 3 secs. Mistake I was making was pressing roof button too soon.
Lock position was turn on ignition while holding the roof button and watch for the flashes. Do you have the instructions? If not I can copy the page and post.
Post #451354 18th Sep 2017 9:56pm
millerj90
@Roadking
I'll give that a try.
I don't have the instructions so a copy would be most appreciated.
Many thanks.
Post #451355 18th Sep 2017 9:59pm
Roadking
Ok, I'll stick a photo on tomorrow.
Post #451356 18th Sep 2017 10:02pm
Roadking
Manual as requested. I tried the lock out this morning and when switching ignition on I didn't need to actually start the engine. Just first stage. Also, wait a bit when you get in before you start the switching. Let the car settle for a minute.
Mike
Manual pictures in gallery. Haven't worked out how to post photos yet. Sad
Post #451371 19th Sep 2017 6:57am
you can view/download these instructions from the topic site... ... - .- -.
Post #451377 19th Sep 2017 7:46am
j_rov
Stan, do you mean jack from an appropriate place behind the wheel? __
Land Rover History:
1976 Series 3 2.25
Post #451385 19th Sep 2017 9:51am
indeed Thumbs Up ... - .- -.
Post #451386 19th Sep 2017 9:52am
millerj90
Mike - Many Thanks
Post #451387 19th Sep 2017 9:57am
