Home > Technical (L322) > 2004 RR l322 driver's window switch
Razoric2010
United Kingdom 2004 Range Rover HSE Td6 Barolo Black
Can I make a left hand drive drivers window switch fit a rhd? Regardless of mounting it can be bodger on propley. I really need some help on this one .....cheers
Post #449085 25th Aug 2017 5:52pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Really don't think so, in the switch pack there is 2 circuits attached with a ribbon cable
Post #449158 26th Aug 2017 3:19pm
Razoric2010
Surely it's just the mount that the wrong way round but the switch it's self is the same ???
Post #449159 26th Aug 2017 3:20pm
i can't recall anyone doing this before..it does make sense that the switch itself is universal though...can you not get a pic of the switch underneath and compare to some on ebay for instance. ... - .- -.
Post #449165 26th Aug 2017 3:40pm
I have a suspicion that you may well be able change the switches as you describe. The wiring diagram for each of the switches is identical.
The only difference seems to be the colour of the wire from the respective fuses.
Definitely worth a serious look. Thumbs Up
Post #449168 26th Aug 2017 4:05pm
Razoric2010
Do u have a diagram that u can send of both??? Just incase u do other wise it's alot of money for not much lol ....thanks again
Post #449174 26th Aug 2017 4:44pm
Try these,
Post #449193 26th Aug 2017 6:39pm
