Home > Maintenance & Mods (L322) > Lower Intercooler hose r/h l322 TDV8 3.6
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Hi, does anyone know how to remove/replace the main lower intercooler hose on the driver side (rhd), the one with the jubilee clip jammed into the chassis?
Done the other side and supposed to be finishing this one tomorrow but I/we can't seem to get at the blasted fastener.
Any help appreciated.
Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #584744 21st Feb 2021 7:33pm
kbald
If it's the top jubilee clip I couldn't get this one done so gave up as a bad job. Can see it easy enough and looks easy to do via the hole when the front wheelarch cover is removed.
Maybe a small Dremel with a cutting wheel would get the clamp off. Or some grips and twist it so it exposes the bolt. I don't think I had a small enough crows foot spanner but that could be another option.
Mine wasn't split so never went that far. Good luck with it Current 2007 TDV8 Vogue Buckingham Blue
Post #584794 22nd Feb 2021 8:42am
RichM63
Cheers KB, yup same as you, gave up and put the rest of the car back together.
Crazy bolt head placement, clearly on a production line when the engine was not in a car! L322 3.6 TDV8 Vogue. 07MY
Post #584841 22nd Feb 2021 4:58pm
