Home > Dealership & Service Feedback > Indy hour rates - £115/hr seems high?
GGDR
Wondering what people are paying around the land for Indy hourly service rates. I'm trying a new to me chap and his rate at £115/hr seems high?
What do you think?
. Cheers, Greg
Post #448217 18th Aug 2017 4:47am
Mikey
Our local main dealer is £130 Neutral
An Indy is generally between £45-60 p/h
However, they are not in London...
Post #448219 18th Aug 2017 4:58am
Somewhat depends on how good he is Whistle
and whether he's charging for actual time worked vs book time
If he's getting it right first time & working at a good pace, then maybe he's good value ?
Post #448227 18th Aug 2017 8:10am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Find a new mechanic at that price,mine charge the job as hourly can be a con I've found over the years with a few places you'd save money going 10 20 mile. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #448229 18th Aug 2017 8:51am
Dolphinboy
£50-£70, the upper for a Ex-LR Mech turned indie.
Craig, what do u charge? That should give a good benchmark.
Post #448231 18th Aug 2017 8:56am
Is this meant to be for the L405 part of the forum? Rates may be different for newer vehicles? .
Post #448234 18th Aug 2017 9:17am
Scottyav
Post #448240 18th Aug 2017 10:14am
supershuttle
I've just been quoted about £260 for six hours, VAT will get sneaked on I'm sure but it's still only 50 quid an hour. the six hours is for a Service, MOT and fitting new supercharger (don't ask Evil or Very Mad ) Geoff
Post #448243 18th Aug 2017 10:20am
chawks
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
Would the labour rate change if the car was newer?? If so sounds much like a con to me
Post #448262 18th Aug 2017 12:22pm
GGDR
Joe90 this is for a 322.
His quote is for a number of jobs; one is 1.5 hours plus the 0 rings for the classic 4.4TDV8 oil pipe problem:
http://www.fullfatrr.com/forum/topic35977....pe+o+rings
So that seems ok to me in terms of number of hours* (*although I have not done this) - it involves removing and replacing the pollen filter box to get to it.
. Cheers, Greg
Post #448327 18th Aug 2017 6:51pm
£76 ph forum price Thumbs Up
Post #448336 18th Aug 2017 9:01pm
GGDR
...and just realised the £115 is ex vat. So that's £138inc
Shocked Shocked Shocked
If you forget about the hours then the oil leak o-ring job is £255inc vat
I don't know how simple/complex this job is.
. Cheers, Greg
Post #448339 18th Aug 2017 9:21pm
Pollen filter removal on L322 - 5 minutes, tops.
Undo 2 x 13mm bolts and pull. .
Post #448343 18th Aug 2017 10:34pm
