![]() | Home > In Car Electronics (L322) > L322 2011 - TV not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
could something simple like not being in a receptive area....the small antennas on the rear screens need a very strong signal so move to a different location and try again.. ... - .- -.
Pete Reid Member Since: 14 Aug 2017 Location: Oxford, England. Posts: 6 ![]() ![]() ![]() |
One thing to try ! |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2672 ![]() ![]() ![]() |
IIRC it's a separate instruction booklet. You have to tune it every time, unless you never move.. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
I've never had a problem with any of mine and I had the tv in motion box (for my passengers only) fitted in the td6 and 3.6. They worked perfectly even changing into different transmitter areas which is quite easy around here!
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
my 2011 TV is next to useless... unless you are parked next to the county transmitter! |
