Home > In Car Electronics (L322) > L322 2011 - TV not working
Pete Reid
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Ok, new to this !!
Have just bought a 2011 MY TDV8 Vogue SE. All good except I can't seem to get the TV working ?? It's got DAB radio and a DVD. I can see the screen and where stations should be but am clueless as to how to get a signal etc. Handbook doesn't mention it and Google just keeps providing pre 10MY info. Any help gratefully recieved.
Post #447937 15th Aug 2017 12:29pm
could something simple like not being in a receptive area....the small antennas on the rear screens need a very strong signal so move to a different location and try again.. ... - .- -.
Post #447939 15th Aug 2017 12:55pm
Pete Reid
One thing to try !
Post #447941 15th Aug 2017 1:15pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
IIRC it's a separate instruction booklet. You have to tune it every time, unless you never move..
Post #447945 15th Aug 2017 2:29pm
stu
I've never had a problem with any of mine and I had the tv in motion box (for my passengers only) fitted in the td6 and 3.6. They worked perfectly even changing into different transmitter areas which is quite easy around here!
I would try as suggested and get in a good reception area first. Mind you outside your house should be a strong signal surely! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447966 15th Aug 2017 8:00pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
my 2011 TV is next to useless... unless you are parked next to the county transmitter! Laughing
probably the most pointless option on a vogue SE.
Post #448328 18th Aug 2017 7:05pm
