Home > Technical (L322) > trans failsafe message
LG17
Hi had the trans failsafe message twice today turned engine off got 100 yards then it comeback on any ideas ? Big Cry
Post #447854 14th Aug 2017 6:49pm
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
1. check battery and voltage
2. get gearbox serviced asap
Post #447860 14th Aug 2017 7:06pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
if you have a gap reset the learned values might help.
Post #447863 14th Aug 2017 7:10pm
LG17
Thanks guys
Post #447868 14th Aug 2017 7:28pm
Gbw321
Having same problem with mine, currently in having a new oil cooler, radiator and gearbox xy position switch fitted, then hopefully not a gearbox fault!
Post #447876 14th Aug 2017 8:08pm
RRPhil
There have been five different transmissions fitted to the L322 and each has its own quirks and issues. To assist those wanting to help, please identify which year/engine you have.
Phil
Post #447879 14th Aug 2017 8:45pm
Gbw321
Mines a 2003 with the zf5 hp24
Post #447890 14th Aug 2017 9:26pm
GraemeC
Please do a thorough search on here before using the IID tool to reset gearbox learned values - the gearbox adapts to wear over time, resetting the adaptive learning can cause serious issues
I recall at least one member has done a reset, which eventually resulted in a new gearbox (there were underlying issues the adaptions masked but still...) - see this thread for starters
http://www.fullfatrr.com/forum/topic22497.html?highlight=learning 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #447971 15th Aug 2017 8:11pm
RRPhil
With the 5-speed L322’s whenever a TRANSMISSION FAILSAFE warning appears you should first check the battery/charging condition – as Gold Ranger stated above (ensure you’re getting 13.5V to 14V across the battery terminals at tickover) and then check that the transfer box will select low range and then re-select high (to test the function of the shift motor potentiometer). Only if the vehicle passes these two tests should you then consider that the transmission may be at fault.
Phil
P.S. I’m not aware of any diagnostics kit which will allow the long-term adaptions to be reset for the 5HP24
Post #447997 15th Aug 2017 11:35pm
LG17
Hi all had to take car to garage they said the gearbox oil was contaminated so need a new gear box reconditioned one £3000 omg :r Big Cry :
Post #448053 16th Aug 2017 4:55pm
Sandyt
Speak to Phil if anyone can point you in the right direction its Phil don't despair yet
Post #448078 16th Aug 2017 8:18pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Been helping a mate out at his garage with customer who has had same problem. Just turned up with wrong gearbox filter but correct oil and seal. Ten year old FFR with original oil cooler. Better get new pipes we said, they will be difficult to get off the cooler we said, the plastic clips become brittle with all that heat and the rubber seals inside perish we said, don't take the risk of them coming off we said. Nope, he didnt want to. Got it all back together on Monday and sent him on his way. Tues night... one of the pipes come off the cooler and spewed all the transmission fluid . So today, new pipes fitted, yet more fluid over me and the floor but gears now fine. Boy though, was that fluid black when we first changed it and I wasnt impressed with the amount of stuff stuck to the transmission cover magnets.. This vehicle is on its 3rd box at 120K !!
Post #448083 16th Aug 2017 11:01pm
@ LG17
Contaminated with what? .
Post #448085 16th Aug 2017 11:19pm
DaveK
deleted
Post #448086 16th Aug 2017 11:31pm
