![]() | Home > In Car Electronics (L322) > Eonon GA 7210 android system. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
this is very interesting , perhaps bobsin can put a list of the exact kit used so others can copy ? also wondering if this method will work with another style of android head unit ?? |
simonzappia Member Since: 22 Oct 2017 Location: adelaide Posts: 6 ![]() ![]() ![]() |
Has anyone had experience with Alvin?
it certainly looks OEM pal , not much on the ad for spec though |
these are the spec's that have been emailed to me:
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Just a little FYI for those peeps who are reading this thread and thinking of applying it to another make of Pink Pong head unit... the Eonon lead has a plug and socket on it... this hijacks the speaker feeds from the BM54, but taps into all the other connections.
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
any vehicle built with the dsp amp will have all it's speakers wired direct from the dsp, NOT the bm54, so the dsp has to be used, unless you rewire all speakers, for which you will need a plethera of crossovers, e.t.c, plus, if u do not keep the bm54, the dsp will not operate, you need the bm54 to keep the dsp amp awake, over the ibus, plus it supplies video signal to the old head should you keep it (in glovebox) . i have not found a new head unit with emulation to wake the dsp yet, if there is one, only then can you ditch the bm54, but then you lose other control functions provided by the original head, i use the old head to switch on my fbh in winter months, with my TD6, for instance. would not wanna lose that, major gadget!! |
I think there was a chap who was driving the DSP with a raspberry computer thing in place of the BM54... that would most likely have been in the original android head unit thread started by Haylands... I haven't got enough days spare to wade through it all |
Gold Ranger Member Since: 31 Mar 2017 Location: East Midlands Posts: 33 ![]() ![]() ![]() |
i know its been while but been mega busy and still not fitted the new stereo yet but today had a go to see if the new unit will work rigged up temporary in the boot
Artiz Member Since: 09 Dec 2019 Location: London Posts: 2 ![]() ![]() ![]() |
Hey folks,
mensagero4u Member Since: 26 Dec 2021 Location: Miami, FL Posts: 1 ![]() ![]() ![]() |
Handy post this 👌 |
