![]() | Home > Duckworth Parts > Some prices please |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Have I offended you Dan? Sorry to hassle, but parts needed as MOT failed please. Drives:
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
I always Private Message Dan as he doesn't then need to look to find your request |
Ok, thanks for that. Drives:
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Sorry Roy completely missed this post flexi pipes or the copper ones? if the latter I won't send shaped pipes via courier due to damage risk You can paypal direct using - www.paypal.me/duckworthparts Please supply your full name address when sending a paypal payment. https://www.facebook.com/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: robin.hall@duckworth.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models ![]() |
Hi Dan, the pipes are the ones that actually connect to the callipers, they are mostly flexible, but have 2 small sections of steel in them (this is the bit that's rotted, big surprise). They go from the calliper, up along the top suspension arm and then connect to the main solid pipes on the body just in front of the axle on each side. They are held onto the suspension arm by two clips each side with allen headed bolts (need the clips and bolts as well please).
Thanks Roy classed as the flexis then, they'd be �90.00inc vat for both and fittings You can paypal direct using - www.paypal.me/duckworthparts
I make that total �244, do you agree? Drives:
Yes that is correct |
Dan, I just about to PM you with some info. Drives:
