![]() | Home > Technical (L405) > Rear judder when pulling away |
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
How are your tyre tread depths front and rear?
neo Member Since: 23 Aug 2009 Location: Trapped in the Matrix Posts: 87 ![]() ![]() ![]() |
I had something similar and it resulted in a new t/box being fitted ..... under warranty of course ... |
Darren.wilkes Member Since: 20 Apr 2016 Location: Bolton Posts: 10 ![]() ![]() |
I have the exact same problem on my 2014 ATB with 60K miles on. Pulling away from standstill with steering wheel turned, results on the rear wheels skipping or shuddering.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
My 2013 SDV8 AB has developed a similar issue. Just been to the dealers for a test drive with a technician and he reckons that there’s a technical bulletin for it. It’s now booked in to be fixed. Not sure what this entails as yet but he did mention contaminated fluids as a possible cause. 2019 L405 SDV8 Autobiography
Got mine booked in with a specialist on Tuesday, they charge £60 for diagnosing the fault. He thought over the phone it could be the anti roll bar bushes, which will cost me £280 to replace with genuine parts.
Dropped off the car yesterday with the specialists and they experienced the fault, during their test drive. They called me last yesterday to advise that it could be the transfer box or the rear diff. They say its a common fault.
Has633 Member Since: 08 Jun 2018 Location: Edinburgh Posts: 3 ![]() ![]() ![]() |
Experiencing same problem. Booked but still not sorted. Booked again for mid June and will pressure them to look at p
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
An MY13 here needed a double flush of the TC oil then a TC calibration. |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Same issue here, I initially thought the rears tyres were slipping on loose gravel, but that’s not the case.
Mine is in at the moment and they've confirmed that it will require a double flush of the TC oil then a TC calibration. It's a known issue and recorded in a TB. 2019 L405 SDV8 Autobiography
Neil183 Member Since: 21 Dec 2016 Location: Rickmansworth Posts: 42 ![]() ![]() ![]() |
Latest update.
Update to my previous post.
Vehicle gone back in. They installed a new transfer box.
