Home > Technical (L405) > Rear judder when pulling away
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Hi
I am 6 months into ownership of my 2013, now 50k mile 4.4 L405 and do love it. However there is an occasional, (which has now become regular) rear judder when pulling away from standstill, only when turning, it feels like the rear diff may be locking.
Sometimes on the dashboard an image of the drivetrain/axles/wheels showing the front wheels turned appears briefly (not sure what this is meant to signify).
Has anybody ever come across this problem before?
Also and im not sure if related or not, but from first start in the morning if I try and drive away immediately rather than waiting 20 seconds or so, it feels like the gearbox is almost slipping and revs raise without moving much. My driveway has a steep slope so dont know if this is normal as my BMW used to do similar.
Thanks.
Neil.
Post #445487 23rd Jul 2017 1:55pm
gizze
How are your tyre tread depths front and rear?
Has one worn more than the other?
I had this on my old ML when the fronts or rears were 3mm or so lower than the other axle.
Also had it on my wife's X3 when the inside edges were wearing more on the front, new tyres sorted it.
Loads of users getting judder when pulling away while turning the wheels with the new Merc CLE as well, they have had to use different tread pattern tyres for the UK (or rather RHD) markets.
All my Mercs have done that with the gear change from cold.
Post #447006 7th Aug 2017 8:07pm
neo
England 2013 Range Rover Vogue SDV8 Santorini Black
I had something similar and it resulted in a new t/box being fitted ..... under warranty of course ...
Post #455645 29th Oct 2017 8:41pm
Darren.wilkes
I have the exact same problem on my 2014 ATB with 60K miles on. Pulling away from standstill with steering wheel turned, results on the rear wheels skipping or shuddering.
Its on the standard 22 inch conti tyres, wear appears pretty even. Its outside warranty, so praying its not the transfer box. I have read on other threads it chould be Transfer Case Fluid or even Suspension Bushes at control arms.
There must be others who have the same fault?
Post #479861 1st Jun 2018 10:05am
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
My 2013 SDV8 AB has developed a similar issue. Just been to the dealers for a test drive with a technician and he reckons that there’s a technical bulletin for it. It’s now booked in to be fixed. Not sure what this entails as yet but he did mention contaminated fluids as a possible cause. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #479899 1st Jun 2018 4:13pm
Darren.wilkes
Got mine booked in with a specialist on Tuesday, they charge £60 for diagnosing the fault. He thought over the phone it could be the anti roll bar bushes, which will cost me £280 to replace with genuine parts.
Please keep me updated with your progress and I will keep you updated with my progress.
I may also call my local dealership in the mean time to enquire about the technical bulletin.
Post #479900 1st Jun 2018 4:22pm
Darren.wilkes
Dropped off the car yesterday with the specialists and they experienced the fault, during their test drive. They called me last yesterday to advise that it could be the transfer box or the rear diff. They say its a common fault.
I am not waiting by the phone for the bad news!
My car is not yet 4 years old and has 63K on the clock, I think its very poor that such an expensive part should fail so soon.
I bought this car from a 67 Year old guy who had owned from new! The car has never been driven hard. Really upset!
Post #480291 6th Jun 2018 9:31am
Has633
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
4.4 sdv8 ATB
Experiencing same problem. Booked but still not sorted. Booked again for mid June and will pressure them to look at p
Problem again . Will probably take this post to show them. Only 38k miles yet
Post #480395 8th Jun 2018 12:55am
GraemeS
An MY13 here needed a double flush of the TC oil then a TC calibration.
Post #480396 8th Jun 2018 2:23am
AMD
Same issue here, I initially thought the rears tyres were slipping on loose gravel, but that’s not the case.
I will get it checked out and post the response from the dealer.
Any squabble and I’ll be looking at the new X5! Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #480724 11th Jun 2018 8:18pm
Buz1500
Mine is in at the moment and they've confirmed that it will require a double flush of the TC oil then a TC calibration. It's a known issue and recorded in a TB. 2019 L405 SDV8 Autobiography
Post #480725 11th Jun 2018 8:26pm
Neil183
Latest update.
Car went to an independent LL garage who carried out the following:-
New front seal on the transfer box
New front flange kit
New oil
and heh presto, so far so good, the fault has disappeared! Very Happy
£586 total, covered by extended warranty.
Hope this helps.
Post #480872 14th Jun 2018 7:13am
Buz1500
Update to my previous post.
I’ve now collected my car from the dealers after they completed a double flush and software update of the TC. This is covered under a technical bulletin. Problem has now gone away🙂 2019 L405 SDV8 Autobiography
Post #481630 22nd Jun 2018 5:36pm
Has633
Judder
Vehicle gone back in. They installed a new transfer box.
Hopefully this solves the problem
Post #483396 13th Jul 2018 8:27pm
