Home > Maintenance & Mods (L322) > Genuine 20" Stormer Alloys
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
I know that these wheels are generally used on RRSs but can also be fitted to FFRRs but can you fit different width tyres on them. Most I have seen for sale are fitted with 275 tyres but could you also fit them with 255 wdith tyres or would that cause problems? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #45572 11th Jan 2011 2:41pm
Vogue
stormers are wider than normal FFRR wheels - 255 will be too vulnerable / narrow for them - you can fit them but they will get knackered very very quickly
also don't let anybody sell you RRS size tyres the FF has a higher profile for 20" rims e.g. 255/50/20
RRS uses lower profile - if you deviate from the rolling radius of this size your speedo will not read accurately by about 10% depending on which profile you use.
Go on line and you can find a tyre profile checker which illustrates the different rolling radius for different profiles and rims
Post #45579 11th Jan 2011 5:03pm
I once bought a FFRR with Stormers and 295 width tyres fitted. They were worn so I changed them to 275 which are perfect for stormers but do have a smaller rolling radius on the FFRR as Vogue pointed out. Best stick with wheels designed for the Full Fat.
Post #45581 11th Jan 2011 5:15pm
GregP
Thanks lads. I'll be following that advice when I get some new wheels. FFRR TD6 HSE
Post #45591 11th Jan 2011 6:17pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Also the RRS 20" wheels are all incredibly easy to ding/scuff with RRS sized tyres on - in nearly 3 years of owning mine I had the full set of wheels refurbed twice while I had the winter wheels on. The winter wheels were 19" with higher profile tyres and I never managed to get them scuffed once, even when I took the car offroad on the Keilder forest drive last February! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #45638 11th Jan 2011 10:49pm
one of the advantages of RRS wheels is that they are 9.5j wide as opposed to the standard FFRR wheels which are 8.5j and the offset is different by 3mm so the wheels will stick out more..this aint a bad thing as the FFRR looks visually better with the wheels filling the wheel arches more than the FFRR wheels..
i have 295/45/20 tyres on RRS wheels and it looks good and taking the fact that they are wider i tend to allow for that when parking and i have still to kerb them...
Post #45653 12th Jan 2011 8:54am
Can I see a picture Scarey?
Post #45658 12th Jan 2011 9:19am
below the waist or above?...
Post #45659 12th Jan 2011 9:24am
Post #45660 12th Jan 2011 9:31am
T24RES
Someone has had your bung outa your armature big boy..... Shocked Ian
Post #45712 12th Jan 2011 12:34pm
Sorry for the hijack. Scary what they've two White blocks above your number plate?
Post #45715 12th Jan 2011 12:39pm
GregP
does look nice scarey. I do like the stormer alloys and have seen them on other FFRR and been impressed.
However I think the 7 spoke vogue alloys from about 2007ish look equally good. Prob gunna be another 3-4 months before I get a new lot anyway so we'll see whats about then. FFRR TD6 HSE
Post #45716 12th Jan 2011 12:40pm
towbar you mean?, its in the garage...
Post #45719 12th Jan 2011 12:41pm
amber tir3 leds rob. Wink
Post #45720 12th Jan 2011 12:42pm
cheers greg, is that the 19'' seven spoke you're on about or the 20''......if its the 20'' then i agree they are nice [and easy to clean].
Post #45721 12th Jan 2011 12:43pm
